Question about Viking 37 in. VGSU161 Gas Cooktop
Viking range - no way to simmer
Recently bought a house with what I think is a Viking VGSU161 gas range, after using electric for many years. Had high expectations based on reputation, but have been frustrated because there is no way to slowly simmer anything on this range. Range runs off propane. Wish I had my 25-year old Jenn-Air electric back.
  • Wendy Cowie
    Wendy Cowie Sep 30, 2012
    I also have the same problem but I use Natural gas which sounds like a conversion kit is not needed. Nothing simmers, everything boils. Very frustrating.
    Novelist:
  • 116 Answers
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
Posted on Mar 11, 2007
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
The unit continually sparks even the gas is turned off. What part do I need? Is this an easy job?
Hi stevebauman,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 20, 2011 | Viking 37 in. VGSU161 Gas Cooktop
Burner will not ignite but electroic spark s are working, sparks will not stop after burner is manualy lit
I have had this same issue with continuous sparking after a burner was lit.
Problem 1. Wet or dirty ignitors/burners. Solution: clean and/or dry (I assume this resolves electrical issues). This has usually solved the problem
Problem 2. Stuck or dirty control switch. Solution: remove knobs and spray electrical-cleaner into switches. AMAZING... no more clicking plus burners now burn hotter when set to HI. I assume this frees-up the movement of the switch to prevent it thinking you are pushing it ON... and thus asking for spark... plus greater range of switch and/or higher flame settings available once lit. A no-cost miracle! ( I used "PureTronics" brand Electrical Contact Cleaner spray can, 1 sec, 2X).
Mike S
Sep 15, 2011 | Viking 37 in. VGSU161 Gas Cooktop
All six of the ignitors on my vgsu161bss cooktop are not firing--- electrical supply is working
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes ...or The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry .
Aug 16, 2011 | Viking 37 in. VGSU161 Gas Cooktop
Viking 37 in. VGSU161 Gas Cooktop looking to replace the grates any help?
LOCATE A SECOND HAND GAS OVEN STORE AND LOOK FOR ANY GRATES I AM SURE THE OWNER CAN LOCATE GRATES FOR YOU GOOD LUCK.
Nov 17, 2009 | Viking 37 in. VGSU161 Gas Cooktop
11 year old Viking VGSU161-6BSS with intermittent gas smell.
STOP USING COOKTOP AND TURN OFF GAS AND GET SOMEONE AUTHORIZED IN AS SOON AS POSIBLE .
Oct 22, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
May 21, 2008 | Viking 37 in. VGSU161 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Viking 37 in. VGSU161 Gas Cooktop Logo
262 people viewed this question
Top Viking Cooktops Experts
Carmen Mikulic
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
