Question about Toshiba TheaterWide 52HM94 52" Rear Projection HDTV
Toshiba 52HM94 no power
At front panel green light is on and the red is blinking, color wheel not moving
  • 2 more comments
  • George Santel Nov 14, 2008
    red light blinks as long as the unit has power, by the way I am a tech. but I don't have much experience with this set and I thought that you have access to a service manual so I can read some voltages coming out of the power pcb. Hope you can help me, George
  • George Santel Nov 15, 2008
    Toshiba 52HM94 Green light on and the red blinking (constantly) no power at all.
    I am a tech. and suspect a power supply problem
    unless there is a typical problem with this sets.
    No schematics. Help please!!!
  • George Santel Nov 17, 2008
    They only list owner manuals (Not sarvice manuals)
    santel
  • George Santel Nov 19, 2008
    Hi there, in reference to this problem... my son
    told me to check in the service manual!!!!
    Is not right to pay for someone to tell me to check for voltages in the service manual!!!!
    I thought you can give an idea or a tip to solve
    this problem.. Thanks, Santel
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
unscrew then check the pcb with a tester
or check the power supply and all the wire
find the parts here
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNumber=52HM95&SortBy=brandname&sortdirection=asc&page=8
Posted on Nov 19, 2008
    Genius:
  • 1,239 Answers
HI This unit has not only problems with the convergence amps but the digital convergence board as well - this is one I would clearly recommend you take in for servicing as opposed to trying the repair yourself... It could be either that's faulty and some elaborate testing with a scope will confirm the failure.
Also, let the tech know that the correct part number for that digital convergence board is: 23786715 (Pd0078d) and to refer to Toshiba's technical bulletins Tv200301 and Tv200301 for further info. This will save them some grief if it does turn out to be the dc board because the part number in the service manual is not correct.
Bill
Posted on Nov 15, 2008
  • 685 Answers
Toshiba Projection TV Manuals here is the manual site
i hope this helps you
    Brigadier General:
  • 6,966 Answers
Initially, the front panel green light indicates that there is power coming into the system; standby light or the red light flashing indicating that the unit has switched to protection mode., the unit in its self diagnosis has detected a fault. In order not to extend the damage, the unit prevents itself from turning on. Eventually the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional or claim warranty repair.
Incidentally, in the hope that this is a simple glitch, perhaps you can try unplugging from the mains and removing all connectors. After an extended period, reconnect and verify connections and try again.
Additionally, was there anything out of the ordinary prior to the incident such as power failure/interruptions, thunderstorm, TV used for an extended period of time, the remotes has been inadvertently played with, or anything noteworthy.
Hope this be of initial help/idea. Pls post back how many times the flash/blinks, back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 14, 2008
  • Louie  Role
    Louie Role Nov 14, 2008
    Welcome to the site George and appreciate the quick reply.
    Initially, to my knowledge, the color wheel would only turn if and when the set has powered up correctly. Often, the problem with them would be noisy operation and/or mechanically stuck hence they will not turn.
    Unfortunately but for the moment, what readily comes to mind would be this service manual for a 52HM85. Here is to hoping it would be nearly identical or at the very least give you the general idea. http://www.eserviceinfo.com/downloadsm/2...
    Would try to source some more. Cheers.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far? Were you able to cross reference the service manual for a 52HM85?
Toshiba TheaterWide 52HM94 HDIM Input
The 52HM94 is a somewhat older set--best guess is it is not compatable for this use.
Aug 29, 2012 | Toshiba TheaterWide 52HM94 52" Rear...
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Red blinking light on the toshiba tv and the picture will not come on
i have toshiba dlp and green and red light keeping blinking model 52hm94
Jul 31, 2009 | Toshiba Televison & Video
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Toshiba
possible color wheel is faulty,call a service shop for an estimate of cost.
Dec 07, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Toshiba 46HM95-Picture Blinking Green
More than likely, as with almost EVERY 46HM95, it's your light engine or color wheel (same thing) starting to go out. The piece alone will run between $500 and $750.. Install prices depend on where ya go. And don't let the Toshiba rep lie to ya. That person might not have known the problem, but Toshiba as a whole has heard about this problem and known about it. If you've searched the internet for the same problem, you'll see that almost everyone that has bought this TV gets the same response from Toshiba "Never heard of it" or "it's out of warranty, tough luck" I'm surprised there hasn't been a class action lawsuit yet.
Nov 02, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba TheaterWide 52HM94 52" Rear Projection HDTV Logo
241 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
