Question about ASUS Eee 4G Notebook
I cant download or install programs from eee download
The computer states that there is an error with the cnr server and also its said **** about a certificate and all i know is icant download or install any thing from your stupid site or any where else please fix my problem i amvery frustrated i tried going to cnr and installing the **** they said i neded and your product wont let me so i am very unhappy
  • Anonymous Nov 28, 2008
    Can someone tell us whether we need to download a program to be able to use this site?
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Dec 10, 2016 | HP Computers & Internet
Computer keeps restarting and stop working
You might have some viruses and malware...
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jul 10, 2012 | ASUS Eee 4G Notebook
We use eee pc by acer, set up the password for the first time. now when i type the correct password, it won't accept it. I downloaded a file called InfraRecorderPortable_0.52.paf.exe, put it in a USB...
Okay, first the password problem. Passwords are almost always case-sensitive now, so make sure that your caps lock is in the same state it was in when you first set the password. I have seen it happen that someone will set the password while their caps lock is on, then when they try to log in later with the caps lock off, they get a wrong password error. More often, though, is the opposite. You set the password with the caps lock off, and are trying to log in with it on.
The second problem is a little more complicated. First of all, the file InfraRecorderPortable_0.52.paf.exe is an installation file, which means it won't do the CD burning as it is. If you want to use the portable version of that software (for example, you have a friend that doesn't have that program on their computer, and they don't want it installed, but you still want to use it)you'll have to run the program and when it asks where you want to install it, select your USB stick. It should be able to run from there without any other supporting programs.
Jun 20, 2011 | ASUS Eee 4G Notebook
Cant download new flashplayer help i have a eee pc 900
If you are using Google Chrome, it automatically will update flash.
http://www.google.com/chrome/eula.html?hl=en&brand=CHMB
For all other web browsers, this will take you directly to the download website and once you install it, restart your computer and it will have flash installed.
http://get.adobe.com/flashplayer/
Feb 26, 2011 | ASUS Eee PC 900 PC Notebook
The only thing that comes up is a Red Cross Antivirus window, cant seem to remove it. I already have an antivirus downloaded.
Red Cross Antivirus is a rogue anti-virus program that is installed via the Fake Microsoft Security Essentials Alert Trojan. This rogue is installed via a fake Microsoft Security Essentials alert that states you are infected and then prompts you to install 1 of 5 rogues, including Red Cross Antivirus. When the program is installed it will reboot your computer and start before you see the Windows desktop. It will then scan your computer and state that there are numerous infected files found, but will state that it will not be able to clean some of them as it requires the heuristics module in order fix them. In order to activate this heuristic module you will need to first purchase the program. This is a scam, though, as none of the files it states are viruses are actually infected.
Go to TrendMicro.com and run a free online virus scan to eliminate this rogue.
Jim
Sep 26, 2010 | Compaq Computers & Internet
Why cant i connect wirelesly on an EPC 7" netbook. Augh. it is set to DHCP. Says its connected then. When i hit internet explorer icon. it states no server found.
You do not connect to the printer via IE? You must first set it up, on laptop as a Network Printer, from add/remove printers, you must install printer, as usual, BUT choose Network Printer Install, then you Browse for it from there, connect to it and then you will be able to print. AFTER you set it all up correctly.
Feb 27, 2010 | ASUS Eee PC 1000HE Netbook
Hi! I am trying to install my 1st 3rd party software onto my Asus eee Xandros netbook cnr to be exact I get to the add part and go through it, at the very end of installation it says: The following...
What software are you installing, onto what OS?
Make sure you are attempting to install the latest version of the software available, and your system has applied latest updates.
See here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | ASUS Eee PC 900 Notebook
Can't get all avira files off of my asus eee
Download and run The Windows Installer CleanUp Utility found here
After its installed run the program
In the white box you will see list of programs installed
Click on Avira and then click remove.
Mar 20, 2009 | ASUS Eee 4G Notebook
Install Java
This will show you how to free up some disk space.
http://wiki.eeeuser.com/optimizingwinxp
Dec 30, 2008 | ASUS Eee PC 2G Surf Notebook
Asus eepc 8mb email errors
About your email, what is your current browser?
If you are not using Firefox, you should get Firefox for Linux. that may work.
Direct Link
http://www.mozilla.com/products/download.html?product=firefox-3.0.3&os=linux&lang=en-US
All Languages and versions
http://www.mozilla.com/en-US/firefox/all.html
Oct 08, 2008 | ASUS A6U Notebook
ASUS Eee 4G Notebook Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
