Question about Samsung SPH-a660/VI660
Fell too many times
Hi, My phone has been dropped one too many times. Recently I noticed a piece from the front was missing which helps it to close (just a small piece by where the little light flashes). Today the whole top came right off, after doing some internet research, I think the "OEM Flex LCD Ribbon cable is snapped". I really don't know anything about fixing a cell phone. Is this worth fixing. I also found an ad for someone selling the same phone for cheap. Might it be a good idea to buy the other phone and use the parts I need? Please help! Thanks, Mary
    Novelist:
    Scholar:
  • 111 Answers
HI Mary As you know that most small cell phone case was made by plastic. Therefore, if you has droppd so many time, the impact causes most damage to the hinges and connector and if you love your phone then you can purchase the OEM housing on Ebay and have someone to replace it. The OEM LCD ribbon is always paired with the main LCD so if you purchase this cable, you should have the LCD as well. However, since you dropped the phone too much, it is not worth to fix if you don't know how. I can fix the phone and can replace anything in it but I still prefer to get the new one since even I know how to fix, parts and time to spend is already cost more than the new phone ususally cheap today if you need to use as a communication tool not entertainment tool or work one like PDA, Smartphone. Phone has too many time dropping will not work well one day and can die anytime. so buy a new one and keep this as replacement part. good Luck. Regards, Jospeh
Posted on May 03, 2007
SOURCE:
Recently front bumper hit and fell off. now I have bouncing problem?
if your tire rolled over it after it fell off then you probably split your tire
also have your shocks adjusted as the weight was relieved on front of vehicle some bumpers can weigh a ton and never notice a shock replacement
Nov 09, 2013 | Cars & Trucks
Key on front face fell off
did u contact any serivce centre or not? what they told
Dec 26, 2007 | T-Mobile Wing™ Smartphone
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Feb 07, 2013 | Nikon D3000 Digital Camera
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
May 21, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
Cavalier convertible rearview mirror fell off
there is a screw that holds that piece of metal in place. take the screw out and remove the piece of metal then look at a local hardware or automotive store and ask for the windshield adhesive. and fallow that instructions pay close attention to the temperature to be applied at and the Harding or drying time.
Oct 11, 2008 | 1996 Chevrolet Cavalier
Front keys on my phone won't respond
My phone did this. It was six months old and Verizon replaced it no questions asked. They ship you a new phone and you have ten days to mail the old one back so you have time to take them both to the store and let the tech move the contacts over.
Sep 26, 2008 | Verizon Communications HTC SMT5800 Cell...
Voice is dropping last word
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel. * Use caution removing and reinstalling the front panel... it's somewhat fragile.
If this does not help, you need to try to run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jul 14, 2008 | Garmin StreetPilot c340 GPS Receiver
LG WM0642H*
Remove the 4 dispenser area screws. Depress side dispenser tabs to drop dispenser assembly from the top lid .Insert an opener or flat item into top lid and front panel space to depress inward the metal lid top hold down clip.Do left side first then right.Raise the lid and look down behind lock mechanism.Or tilt washer and look underneath. It's an open area below?
Apr 28, 2008 | LG WM0642H Front Load
Samsung SPH-a660/VI660 Logo
53 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
