Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Drivers of Philips Projection TV
I have Philips Projection TV Model 46PP8621 When i attach it to my laptop, i asks for Display drivers of new hardware found. I have windows XP SP 3 on my laptop
Ok ha
Posted on Nov 21, 2008
I need drivers for laptop model w76s
It is not your laptop that needs drivers, it is the hardware you need to connect to the operating system that needs a driver. From Windows 7 and up, Microsoft only allows drivers, if the manufacturer asked for certification. If the hardware and driver is certified it is also on the Microsoft website. Most of the time if you use new hardware the operating system goes to Microsoft to see if there is a correct driver and then installs the driver.
For older hardware, only few manufactures make drivers and ask certification. Most only develop drivers for their new hardware. So for older hardware there are only a few drivers. If Microsoft can't deliver drivers, or the manufacturer from the hardware can't, you are lost. The devices won't work with the new operating system. Nobody told you that before upgrading.
Jul 09, 2014 | Computers & Internet
Philips rear pro 46PP8621 ..fuzzy image, lower screen has a wavy section with distorted image, very noticeable with text.. this section is a bright green colour. Colours seem to be ok......... with...
Your tv is probably in need to replace the color disk. Follow instructions on last pages of your manual to find out hou to get repair service.
Jul 24, 2008 | Televison & Video
When i connect 500GB External USB hard disk on winXP machine .I get the display on my PC that new hardware found & asking for Drivers
Let the system to search for drivers automatically. Before proceeding that place any driver cd into the CD drive if came along with your ext. harddisk so that the drivers from CD will be automatically taken by the driver installer.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro 500GB External USB...
I want to hook up a Toshiba laptop to a Panosonic rear projection
VGA, and supervideo only carry the visual signal, so if you use one of this cables, (both the computer and the tv have to have the same output/input) then you have to have a cable attached to the computers audio output to carry audio to the TV. If your computer has HDMI output and the tv has an HDMI input, then that carries both visual and audio. When you attach the video cable to the tv, put the tv on that input source and the computer will sense the device and if the drivers are updated will fire the signal up automatically and give you the choice of using only the tv, or using both the tv and laptop monitor.
Sep 27, 2009 | Computers & Internet
I have compaq presario C700 Laptop model no. C772TU having sound problem in windows XP SP-2.
soundcard problem solution
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click system device
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
7. then it will start scanning your new hardware and ask for the installation drivers.
if not sovled try this..
8. Right click on Mycomputer, select properties
9. Select hardware
10. Select Device manager
11. check is there any yellow color pointed is display on any option if yes,then right click on the
12. then select Action from the menu bar on the top and select scan for hardware changes
13. then it will start scanning your new hardware and ask for the installation drivers.
14. then goto system device
15. double click system device
16. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
17. then select Action from the menu bar on the top and select scan for hardware changes
18. then it will start scanning your new hardware and ask for the installation drivers.
19. close it
20 restart your computer
I believe your problem may solve..
regards
Ehsanullah.
Jun 18, 2009 | Compaq Presario 700 470024-192 Notebook
Installing Philips SAA7130 TV drivers
No solutions yet. Be the first one to submit a solution!
Apr 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Drivers
you can install your own drivers
contol panel add hardware
click next then yes already attached
then for audio scroll down and click add new hardware then follow instructions
for video driver follow same except click display adapters
if not found click next then and then choose from list
if you know the type of driver click on it on left side then in right side model then next
LET ME KNOW IF THIS HELPED
OR IF YOU NEED MORE HELP
Jan 20, 2009 | Creative Labs Audigy 2 ZS Notebook Sound...
Convergance issue Philips
yes it uses ywo STK392-120 ICs and there are also 11 6.8 ohm 1 watt resistors. You can get the parts at the following link.
http://servicemanuals.vstore.ca/
Sep 11, 2008 | Televison & Video
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
