Question about Compaq Keyboard
Keyboard randomly double spaceing when pressing space bar.
Normally, when i hold the spacebar, there will be an space, half an second delay, than it starts adding spaces...
Well,apparently the half an second delay is gone, and randomly while typingan message (like 10 times so far while typing this out) it adds anextra space... It's really annoying. I installed the keyboard wirelessmedia keyboard drivers from the disk that came with the package, butthat didn't fix it...
Also I should probably mention, i had this keyboard for about 1 to 1 and an half years so far.
Also, apparently this site doesn't have my product, and it wouldn't post my question without entering an one that they know, so my keyboard aint an compaq, it's an "Labtec® Media Wireless Desktop" (http://www.labtec.com/index.cfm/gear/details/AMR/EN,crid=28,contentid=711)
  • goldfinger6 Nov 14, 2008
    EDIT: I found the correct section to post this in, so if you can help me, go to here:
    http://www.fixya.com/support/t1245482-ke...
3 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: I HAVE A COMPAQ KEYBOARD. I DID SOMETHING STUPID.
Try getting the cans of compressed air you would get at an office supply store, power down the laptop and trydrying the board with short bursts of air, there may be some dampness under the keys interfereing with the imput signals from the key pads.
Posted on Oct 05, 2009
  • 40 Answers
SOURCE: My dog knocked over my Compaq keyboard. Now the
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Posted on Mar 08, 2011
Wired and onscreen keyboard space bar doesnt work
Keyboards are cheap. If you need to use this one then you will need to carefully pop the spacebar key out, turn the keyboard upside down and give it a good shake. You will see a ton of junk fall out ;)
Mar 08, 2014 | Computers & Internet
Space bar sticking keyboard
There is something under the space bar you can pry it up carefully and remove the debris it should snap right back in.
Oct 31, 2013 | HEWLETT-PACKARD Computers & Internet
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Mar 08, 2011 | Compaq Keyboard
I have a IBM WW 1500 all the keyboard works but the spacebar, is this the function or keyboard or possible homming sensor failure?
If everything wirks but the space bar you probably have a keyboard problem. If someone had the space bar off it may not be properly installed. You can pop the space bar off and look for debris under it.
DickyO
Dec 02, 2010 | IBM Office Equipment & Supplies
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Space bar does not work - any suggestions what is wrong?
Assuming this is a WW1000 the space bar will come off with a nlittle prying pressure under the center of the bar. Remove it and check for debris under it.
DickyO
Dec 10, 2008 | Lexmark Wheelwriter 1000 Typewriter
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Compaq Keyboard Logo
121 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
