Question about Pioneer AVH-P7500 Car DVD Player
Front panel button illumination
I cannot get the lights to display on the removable front panel. I am refering to the buttons which used to illuminate on the panel. The only one that works is the REAR ON button which illuminates red and blue correctly. Cannot find anything in the Operation Manual. I recently had the unit repaired by Pioneer for a faulty ribbon cable on the fold down screen and cannot recall the buttons illuminating since - but note one button does work. Any asistance will be greatly appreciated. Thank you.
SOURCE:
Jexx
  • 148 Answers
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
Posted on Nov 05, 2006
SOURCE: Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Posted on Jan 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Pioneer Premier deh-p330 player,illumination color
CLICK HERE for your manual.
Unfortunately for you, this Head Unit does not have the function you want.
The display is green by the factory, and the type of display installed cannot be changed or customized.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 25, 2009
  • 16 Answers
SOURCE: how to change color display
to change these types of setting you must turn off the stereo (hold off) then PRESS & HOLD the menu button (mines a different model but the menu button is pressing the volume knob )
Posted on Jun 02, 2009
SOURCE: some functions not working
I think you to ground the parking brake wire in order for all of you setting to illuminate. I'm not sure but I'm thinking that I had the same issue when I was installing mine.
Posted on Jul 13, 2009
I replaced the toner and drum and I still have the error mesage
You may not have reset the drum counter. If multi-function machine open front hatch , press clear or options button. Display should read "change drum?" then press number 1 on keypanel. Display should read "accepted" then close hatch. If the machine is printer only locate the "go" button on the front left on top of the printer. Open the front hatch and locate the stud under where the "go" button was. Press and hold the stud until all the lights are illuminated. Relase the stud and close the hatch.
Oct 16, 2014 | Brother MFC Office Equipment & Supplies
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
ASUS MOTHERBOARD A7V8X-X FRONT PANEL WIRING DIAGRAM
Most of the wires on the front panel are just for LED Lights other than the Power Button. Look on the motherboard for the abbreviated spellings of PWR for the Power Button, RST for Reset, HDD for Hard Drive, etc. Only the PWR will keep your system from booting up. If you place the others on the wrong set of pins the Led light will not illuminate.
Jun 02, 2012 | ASUS Computers & Internet
How to connect a third controller
-Remove the battery cover on the back of the remote and press and release the red SYNC button inside the cover. The lights on the front of the remote will blink.
-Open the SD card slot cover on the front of the Wii and press and release the red SYNC button also.
-When the lights on the front stop blinking, the connection is complete. The light that is illuminated indicates the player number (3 and 4).
May 29, 2011 | Nintendo Wii Console
We have just bought an LG 23 inch monitor. Everything okay on it except for the proper resolution. The monitor no. is W2343T. I have put the resolution of 1920 x 1080 and frequency of 60 hertz on it as...
I think the problem is going to be in the Windows software, and not the settings on the monitor. Not sure which type of computer or which Windows you're running, but get into control panel, monitor settings and see what you can do. Windows help and support might be able to assist you.
Here's an excerpt from ncix.com:
Cons Clumsy front panel controls
Vertically, picture is no larger than my old 17"
May require video card upgrade for higher resolutions
Front panel illuminated power button is distracting
Summary Overall, I really like this monitor. But don't expect a size increase vertically over a 17" display. I actually lost half an inch. I prefer a 16:10 aspect ratio so I'm not actually using the full wide available. If you're like me you can save some change and go for the 2243.
Not sure if that will help, but there it is.
Here is the whole blog:
http://ncix.com/products/index.php?mode=productreviewread&product_id=37490
Not sure if this will help, but you might check it out:
http://www.sevenforums.com/graphic-cards/19981-cannot-display-1920-x-1080-a-2.html
Good luck, and hope this helps.
Sep 20, 2010 | LG Computers & Internet
Hi my tail lights will not come on when my front
Hi,You have a tail light/insterment panel light fuse.the fuse is blown.hope this helps.Thank You for using fixya.... iluv2fish.....Ray......
Jun 15, 2010 | Cars & Trucks
How to reset lexmark e260dn on factory defaults
1.Turn the printer off.2.Open Front cover.3.Press and hold X button.4.Relese X when the ! LED is illuminated. Note:Be patient as the LEDs will light up in multiple patterns before finaly stopping at !.5.Close front cover. Note:Observe that green button and 3 other LED will be illuminated at the same time.This is Home position.6.Slowly press X button until the 3 first LED are illuminated (paper,toner,light)Note:normaly this will require you to press the X button 11 to 13 times depending on the options and features installed.7. Press and hold green button until all LED flasch or strobe from left to right then relese the button.wait until this process stops with the same pattern as step 6.8.Press and hold X until the light pappern return to the pattern of four LED in the Home position.9.Turn the printer OFF.10.Turn the printer On.Note:if on a DHCP network, wait 30 seconds to see if the DHCP server/router sends out an IP adress to the device.11.Press green button to print a setting pages and observe that all the TCP/IP settings have been reset.12.Reconfigure the device using DHCP.Auto IP(zero configuration) or the IP Setup Utility.
This is my solution to the problem.//Oaklunde
Jan 19, 2010 | Lexmark E260dn Laser Printer
Gmc sierra 2008 low tire pressure problem
You can follow this to reset it.
Ignition ON, initiate the TPM Learn Mode
using one of the following procedures:
  1. On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  2. On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  3. Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
    When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
    Ignition OFF, adjust all tires to the recommended pressures
Jan 22, 2009 | 2000 GMC New Sierra 1500
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Pioneer AVH-P7500 Car DVD Player Logo
43 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
