Question about Admiral AAV7000A
Machine won't stop filling
My Admiral 5.2kg machine (model A6964)starts filling and won't stop in both the wash and rinse cycles. The cycle doesn't seem to advance at all. Very occasionally it does work, but most times it will not. Cheers for any help!
  • 1 more comment
  • washgirl Jan 12, 2008
    the machine continues to fill and drain simmutainiously. does not aggitate even when dial is turned mannually. Dial does not advance.
  • washin hell Apr 19, 2008
    wont stop filling and draining at the same time was told to connect to non vented outlet pipe.
  • joan92663 Apr 21, 2008
    The washer will run the cycle but either not drain for spin cycle or will drain and refill during spin cycle.
Isn't there a water level switch that tells the selenoid to shutoff the water? The waster turns off when you go to off so it appears the selenoid works... Is there a float switch?
Posted on Jul 20, 2008
Sounds like your solinoid valve needs replacing. It cuts the water off when it has reached the right level.
Posted on Apr 14, 2007
  • Lisa Rainey
    Lisa Rainey Feb 15, 2014
    This wasn't my question
After 2 yrs. the cold/cold selection doesn't work at all but the other selections give me hot h2o only. Also, rinse cycles just stopped working!
Your water inlet valve has 2 electric coils on it. One for hot --one for cold. The cold is probably bad. Most newer machines use COLD rinse only so if no cold fill it just stops in the rinse cycle. Replace the inlet valve which is the part on the machine back the hoses hook to.
Mar 23, 2015 | Admiral AW22 Top Load Washer
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
one of 2 things, either the inlet valve is not shuting off or the pressure switch is not sensing the water level. both of witch would have to be repair by a qualified technician. this repair would be worth doing
Feb 17, 2008 | Admiral AAV7000A
Admiral AAV7000A Logo
173 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Marvin
Marvin
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
