Question about Dryers
Ceiling fan Thank you so much for your helpful response - I will get a new fan!  In the meantime, is the high pitched noise representing a danger?  As I said, I turn off the circuit breaker (which turns off everything else on the circuit) but the fan still makes that high pitch noise.  Is there a hazard until I can get it off the ceiling? Thanks again Susan
  • susanhelp Nov 17, 2008
    The problem was an external issue as I believed Benimur mentioned.  That stuck with me and sure enough was the root of the problem.  Thanks!
    Brigadier General:
  • 6,966 Answers
Sorry for the delay in response. Electrically, there should be no potential hazard since there would be no more "juice" running through the circuitry.
Posted on Nov 14, 2008
I have have high pitch wind noise from fan clutch after replacement is it normal on new fan clutch
Fan clutches are stiff and loud till vehicle runs a bit, as fan clutch mechanism warms up drag on clutch mechanism releases pressure and will free wheel.
Do not mistaken this with, when engine hot, clutch engages to help cooling system which is normal.
Feb 17, 2015 | 1997 Ford F150 Regular Cab
Why does my new Frigidaire FFHT1826 make a high pitch noise
Thank you for your post, friend!
Based off the information you have provided it sounds like you are hearing the compressor come on. In the newer, high-efficiency compressors they operate much faster than the older models and some may put out a high pitched hum or pulsating noise. I hope this helps. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Fan only wobbles on high....recently 'bumped'
Check all your screws especially the set screw at top of fan that goes into rod. Blades could be warped from the water. Ball of fan not set in bracket correctly. When your buying a fan, look for blade pitch.13 degree or better is best. You shouldn't have to use the fan on high unless it's a low-end fan with a low blade pitch. It's costing you more money to run the fan on high. Sorry to get so preachy, I'm a fan dealer .
Jun 19, 2013 | Dryers
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Someone helped me install a ceiling fan. I told them that I here a clicking noise still , they said to go back and tighten every screw. I did that but the clicking noise is still their. What are my...
Check that all the blades are aligned when the fan spins. If one blade is higher or lower than the others it throws the fan out of balance and makes a clicking noise. Also check that the pitch on all the blades is the same, this has the same effect. The blades can usually be bent just a bit to correct any misalignment.
Jun 09, 2011 | Hunter (25417) Ceiling Fan
New Broan fan rattles
I would take it back for exchange...
($159... is high end pricy... Amazon = $168 (worse)).
Old ... tired fans can dry out... gather dust.
Their life can be significantly extended with
fresh lube... As for me...
I've learned to just find & buy a NEW MOTOR.
But a new FAN... Outrageous!
Take it back
... Broan-NuTone Nutone Is a QUALITY
FAN... Expect quality.
Apr 20, 2017 | Broan-NuTone Nutone QTRN080 Quiet Test 80...
Our ceiling fan do not move any air at all.
hello sir/mam
please confirm you have fixed the blades as per the manufacturer and then you can change the pitch.
Sep 14, 2009 | Hampton Bay 24750 Huntington III Ceiling...
High pitch noise from the flyback
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Jan 23, 2009 | Samsung HL-P6163W 61" TV
My ceiling fan - Casa Viejo
Nov 14, 2008 | Dryers
Dryers Logo
246 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
