Question about Eclipse SW9102 Car Subwoofer
Subwoofer seem to be broke
Hello, while I think that one of my subs had been damaged by an amplifier who was not working correctly. The amplifier damage only one of my subs!! Now, when I press the subs when all is off, it is ok no sound. But the other subs make a little sound when I press it. And when it play the subs seem to make a little sound like a wink wink, but it play louder as the other.. but I am scare that the sub will maybe in the future broke if I continue to use it, or there is a way to fix this problem?? Thanks again!! Sam
  • 62 Answers
The one sub that you described is gone, there should be no reistance at all when you push on them. It sounds like you got your gains set to high on that amp (maybe the amp is underated for your subs). When you turn up the gain to high your cause your amp to distort and it can get as bad as sending a pure DV current to the sub. That DV current will blow subs because of all the force directed in one direction. If you think about it the amp takes a DC current and turns it into a AC current which creates the frequecy (rate at which it alternates) that alternating current pushes and then pulls on the sub keeping it within its boundries.
Posted on Mar 25, 2007
Will a pioneer receiver vsx d309 run 2 8 ohm speakers and 1 jl audio w3
It will drive the speakers but not the subwoofer. U need to connect the subwoofer pre- output from your amplifier to another amplifier that will drive the subwoofer.
If you connect the subwoofer directly to your amplifiers speaker output it will force the subwoofer to play the entire spectrum of frequencies (not designed to do that) consequently causing damage to the sub and maybe even the amp. So use the sub pre out.
hope this helped
....andy....
Dec 29, 2013 | Pioneer Car Audio & Video
Tip
How to wire subwoofers correctly.
If you're ever unsure about how you need to wire your subwoofers to get the correct ohm load to your amplifier there are a few resources to help. Usually in the owners manual that comes with your subs and your amp they include a detailed ohm load calculator. First step is to determine what subwoofers you have. Common subs come in a dual 2 ohm or a dual 4 ohm version or a single 2 ohm or a single 4 ohm version. Next determine what ohm load your amplifier is rated at. Mono "subwoofer" amps usually are rated x amount of watts at either a 2 or a 1 ohm load. This means you need to purchase the correct subwoofer combination to match your amp. If youre purchasing 2 dual voice coil 4 ohm subs then to maximize an amp you should buy a mono amp stable at 1 ohm. and Dual 2 ohm subs would need a 2 ohm stable amp wired in series parallel. A great resource for a beginner is to go to www.the12volt.com and on the top of the page find the words "subwoofer wiring diagram" and click on it. This will bring you to a drop down menu where you choose the number of drivers "subs" or "speakers" you have and then you choose the impedence in the next drop down menu. Next you'll be provided with multiple wiring options. Good luck and never think you can't do it yourself. Once you learn it's very easy to retain.
on May 31, 2010 | Car Audio & Video
Is there a crossover in the ada885 sub box do i disconnect when using external amp
usually the external amplifiers have potentiometers that you can adjust called sub sonic and LPF. Find what your sub needs to be setup to and set the LPF to that frequency, usually 40-60hz.
Find the tuning of your box or the sub sonic frequency cut-off and set it there. usually 30hz and under, this will keep your subwoofer from unloading and damaging itself.
Nov 10, 2013 | Car Audio & Video
No sound from subwoofer
If your subwoofer does not work on your altec lansing speakers,
more than likely you blew the subwoofer amplifier board.
I have an ADA-885 system and bought it brand new back in
November 2000 and has been flawlessly operating great up
until this past month when my subwoofer went out but my
"satellite" speakers kept working. After disassembling the
subwoofer box I first noticed that the subwoofer amplifier
board is seperate from the rest of the grouped boards for
the dolby and satellite speakers. The subwoofer box is
designed to use the air from the subwoofer to actually
cool the amplifier boards inside the unit, great feature
until your subwoofer goes out, that is when your main
amp will more than likely fail soon after the sub amp
fails, as it uses the air from the subwoofer to keep the
amps cool. I know this might be an older post but
hopefully I can put it in the right category to hopefully
be able to help someone out in the future.
You can test the ohms of the speaker with a multi
tester. It's a dual voice coil speaker, 6 ohms each.
Well my system is broke and needs another
subwoofer amplifier board so if anybody reads
this and has this subwoofer, I need my sub amp
fixed ! or if you have the subwoofer unit maybe
and nothing else to go with it but the subwoofer
lights up, give me a jingle, I'd buy it from you !!
Jul 23, 2011 | Altec Lansing ADA 885 Computer Speakers
I parelled one 15" q power subwoofer to my brideged pioneer amp.The amp got really hot and blew a fuse.How should I wire my dvc subwoofer to the briged amp.
Hello sir, hi, YOU DON'T bridge no more speakers, this upsets the impedance load of the amp. to install another sub-woofer, get another amplifier. You may have damaged your power amplifier, If you experience repeated fuse blows, your power amplifier is now SHORTED. This needs IC amplifier replacement.
Aug 19, 2010 | Pioneer GM-5300T Car Audio Amplifier
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Jul 06, 2009 | Car Audio & Video
Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
Audio problems
It sounds like this is a subwoofer box with a built in amplifier, is that correct? The issue you describe definitely sounds like a problem with either the amplifier portion or the signal to the amplifier. Do you have a way to confirm that the signal is getting to the amplifier from the head unit such as an oscilloscope or a known-good signal that you could try when the subwoofer doesn't seem to want to work?
Oct 24, 2017 | Mac-Audio Compact 225 Car Subwoofer
Subwoofer Line In/Out Mix-up
I had a problem with no audio and I recently found the fix. When the sub still worked and you turn it on you hear one relay click and then about 5 seconds later a second relay clicks and the audio comes on. The problem I had lies with that second relay. When you take the case apart there are 4 circuit boards. The big board with the two big blue capacitors is the main board. Well next to the two blue capacitors is a blue relay. That relay had a pin that came un-soldered from the circuit board. I re-soldered that pin and the sub works just like new. If you go here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.html you can find a free service manual that has the wiring schematics for the amp. Hope this helps!
Nov 10, 2007 | Sony SA-WM500 Subwoofer
Eclipse SW9102 Car Subwoofer Logo
93 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
