Question about Zenith Televison & Video
I would like to change the start up channel setting.
The Concierge TV I purchased used wants to always start on channel 63. I want to change it to start on channel 3 for start up.
    Problem Solver:
  • 15 Answers
If you are using satellite or something that use channel 3 and there are no other channels(cable) do a channel scan from the menu of your tv.if you have an antenna or cable hooked up temporarily unhook it so when you do the scan all it finds is what you have on channel scan may also be called autoprogram depending on your tv
Posted on Nov 14, 2008
Hello, I have a Zenith Concierge model number
Jul 02, 2017 | Televison & Video
We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
Jan 22, 2009 | Televison & Video
I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Dec 13, 2008 | Zenith C27A24T 27" TV
Concierge Hotel TV - Volume Control
If there are no chasis numbers on the outside you may want to open the cast and check for numbers there. Then you might be able to google the number and find a manual. some TV's willl enter the menu or rest by pushing two buttons at once on the set. This could change your channel selection however.
Nov 14, 2008 | Televison & Video
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on or
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Zenith Concierge hotel tv wont work with my xbox 360
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
Mar 19, 2008 | Zenith C27A24T 27" TV
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Televison & Video Logo
420 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
