Washing quit working at spin cycle, makes funny noise
Started cycle over and now it wont even drain the water.
  • 63 Answers
Pump or coupler prob depended on washer type
Posted on Nov 14, 2008
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Wont spin the water out
check for the DRAIN MOTOR PUMP , located where the DRAIN HOSE is attached to ,it could be clogged,
hpe it helps , AJ
Dec 21, 2009 | Frigidaire GLTR1670A Front Load Washer
Water wont drain and it wont go into the spin
if it is'nt making anny sound at all in spin its probly the lid switch
Dec 08, 2009 | Magic Chef Washing Machines
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
Washer will spin but won't drain automatically
are you sure it spins? usually something is in the pump like a sock. You could remove the front and take the hose off the pump to see if its clear. It also sounds like it could be the lid switch. if you have to close it make sure you hear a clicking noise from the lid switch.
May 14, 2009 | Maytag Washing Machines
The spin cylcle does not work . It makes a funny noise and does not spin
the drain is probably clogged you'd be surprised home much is in there
Apr 26, 2009 | Washing Machines
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
