Question about Zenith DVP615 Portable DVD Player
Dvd player does not play disc
My dvd player is less than a year old, it gets used often. One night my 17month son dropped it on accident. (not from a high distance though haha) Anyways now it will not play any movies. It will load but the disc will not spin and the monitor says no disc. Please help we are planning to travel a far distance for the holidays and we need our dvd player. Thanks!!!
  • 03duramaxden Dec 12, 2008
    MY Wife's DVP615 motor won't spin now so it won't load, is it trash or treasure
  • 684 Answers
Use a CD cleaner and try to use the CD......If u still have the same problem.....
If the CD is under warranty please donot open it give it for service.....
If it is out of warranty i would request u to open the cover u will see a white strip going from the optical lens to the board....Just remove that strip and reinsert it if still it doesnt work the optical lens may be defective.....
Posted on Nov 14, 2008
Will not read disc
As it's less than a year old the manufacturer's warranty should still apply.
Your player probably has a failed laser head unit; if you have to pay to fix this fault then you'd be better off just chucking it away and buying a replacement as it will be cheaper.
Mar 15, 2010 | Sharp AQUOS Blu-ray Disc Player
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Not playing dvd saying no disc
You can try a cleaning disc. If the unit is less then a year old I would have it serviced under the manufacturer warranty. If you still need further assistance please let me know.
Thank you,
Aug 08, 2009 | Philips DVP642 DVD Player
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Dvd stops playing and freezes less than 6 months old
Try to use lens cleaner. If lens cleaner doesnt solve the problem. Check your warranty. Or inquire to the store where you bought it.
May 14, 2009 | TruTech PVS12701 Portable DVD Player
DVD no longer reads any discs and won't play.
remove cover of dvd player, than use a cotton swab and rubbing alcohol and clean the lens. if it still doesn't work than I would suggest buying a new one. you can get a decent player for just $30 new
Mar 31, 2009 | Televison & Video
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
Regional code error 4 RCA L32WD26D
It's possible your son may have by accident entered into the service mode for technicans. At this point, I think you would have to call the RCA for help on this one. Good Luck
Jan 24, 2009 | RCA L32WD26D HDTV/DVD Combo
Record on DC210 and playback on home DVD
You should absolutely be able to play the recorded DVDs from your camcorder in your DVD player, as long as you remember to finalize the disc and the disc is compatible with the player. If your DVD player is less than five years old or so, you should be fine, provided you're not using dual-layer discs.
Dec 02, 2007 | Canon DC210 DVD Camcorder
Durabrand DUR10 not playing
Less than a year old - take it back and get it replaced
May 21, 2007 | Durabrand DUR7 Portable DVD Player
Zenith DVP615 Portable DVD Player Logo
148 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
