Question about JVC GR-D290 Mini DV Digital Camcorder
Black lines in play mode
When the camcorder is in play mode both on the lcd screen or hooked up to a tv, there are horizontal black lines throughout the screen. There are 4-5 wide lines and you can see the recording in the background
  • junior28570 Dec 10, 2007
    I'm having the same problem with my GR-D275 :(
  • tulp Jul 10, 2008
    I also have black lines on the video sccreen and on my Mac while I'm trying to copy..please help me...i am getting frustrated
  • 30 Answers
This sometime appears when the camera hasn't been used, this dissappears after sometime of playing.
Posted on Aug 30, 2007
Horizontal lines showing behind tv menu
Normally the menu is generated in the LCD Control Unit. If your menu looks good, but the defect is behind the menu, I would suspect the Main PCB. Good luck to you. Part# is DUNTKD934FM01-V1.
Jun 17, 2016 | Sharp Aquos LC46D62U 46-Inch 1080p LCD...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
Sharp 32 in lcd tv has small horizontal black lines throughout whole tv
a model number may tell me more===trace lines at a slight angle?
More information needed here----
Mar 23, 2012 | Televison & Video
Horizontal "running" lines throughout the tv
You have a defective LCD panel. If it is under warranty, exchange it ASAP. If not, it's time for a new TV, as it is usually more expensive to repair it than buy a new one.
Jul 06, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Black Horizontal Lines on Philips Cineos 50" Plasma
First you want to determine if the issue affects the tv's menu if it does you are looking at a Light Engine issue which is expensive if it does not interfere with the On Screen Display the issue is with your signal board, also check to see if this happens on multiple inputs with multiple signal sources if it doesn't you just might want to use a different input which is a way cheaper solution
Aug 06, 2008 | Philips 42FD9932 42 in. Plasma Television
Panasonic GS35
i suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
Jun 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
JVC GR-D290 Mini DV Digital Camcorder Logo
307 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
