Question about Canon PIXMA MP160 All-In-One InkJet Printer
Menu letters in tool button
There is no explanation in the manual relating to the letters that come up when I press the tool button repeatedly. Please tell me what they mean, this is frustrating.
Arthur Tully.
  • sneakynev Nov 16, 2008
    Thank you very much. Yours is a great service.
    Arthur Tully
  • 421 Answers
The letters refer to the following:
A = Prints the nozzle check pattern
H = Cleans the fine cartridge
Y = Fine cartridge deep cleaning
P = prints head alignment sheet
L = prints the fine cartridge alignment sheet
U = Scans and then aligns the sheet you printed under the L option
All in the user manual in Chapter 9. Download a copy here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368
Posted on Nov 16, 2008
I can not set English on my 5400 it is stuck on German. How can I change the language to English?
Changing the Display Language
To change the display language, please execute the following steps:
Step Action 1 From the control panel, press Copy Mode. 2 Press pattlnk_10122006_1256-menu.jpg. 3 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until Tools appears. Then press the pattlnk_10122006_148-okay2.jpg button.
4 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until Device Setup appears. Then press pattlnk_10122006_148-okay2.jpg. 5 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until Language appears. Then press the pattlnk_10122006_148-okay2.jpg button. 6 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until the language required appears on the display. 7 Press pattlnk_10122006_148-okay2.jpg to save the change.
Jun 07, 2011 | Lexmark X5470 All-In-One InkJet Printer
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
I have a yamaha receiver. Zone 2 is not playing any sound. When I go to adjust the volume it says "zone 2 volume fix". I saw these directions below on your website to help solve this problem. However,...
Hi
could you send me the model of your yamaha.
Please use the add a comment link, as if you accept the solution I will no longer be able to respond to you.
Thanks
Jun 20, 2009 | Audio Players & Recorders
Frozen nano
First try this:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
  • If that doesn'e work, then try this one:
    1. Open the Control Panel.
    2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
    3. Double click on Computer Management.
    4. In the left column, click on Disk Management.
    5. Locate the iPod and right click on it, then click Change Drive Letter and Paths.
    6. Click the Change button.
    7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
    8. Click OK.
    9. Click Yes on the confirmation dialog.
    10. Close the Computer Management window.
    11. Restart your computer.
    Jan 20, 2009 | Apple iPod nano
    Zone 2 issues
    FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
    Aug 03, 2008 | Yamaha RX-V659 Receiver
    My ipod says www.apple.com/support/ipod Blinking on and off with the apple symbol displaying.
    Hi
    try this out
    2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
    or
    8. Click OK.
    or
    1. Before placing the iPod into disk mode, you should verify that it is charged.
    2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
    3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
    4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
    5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
    If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
    If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
    Jul 31, 2008 | Apple iPod MA446LL/A MP3 Player
    No zone 2 sound coming from yamaha amp rx-v861
    We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
    1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
    2. Press the [SET MENU] button on the remote control.
    3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
    4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
    Feb 16, 2008 | Yamaha RX-V661 Receiver
    Zone 2 Vol Fix
    Try this:
    FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
    Jan 19, 2008 | Yamaha RX-V657 Receiver
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    134 people viewed this question
    old marine
    old marine
