Question about Toshiba 61HX70 61" Rear Projection Television
Blinking power light
I have a 61H71 it won't turn on . the power light just blinks it was acting a little funny on the top of the picture some times ,worked fine the nite before and just wouldn't turn on the next morning
  • tonyfires Apr 06, 2008
    blinking power light after a power surge
    checked 1 fuse I don't know where others are.
    Problem Solver:
  • 15 Answers
Try to desolder the convergence ic's the plug the unit if these ic's causes the problem the unit will turn on after desoldering it,if still it wont turn on try desoldering the fbt if it is deffective it will turn the unit off desoldering deffective fbt will verify the problem the unit will turn the b+ on
Posted on Aug 19, 2007
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Posted on Dec 30, 2006
2 Suggested Answers
SOURCE:
  • 359 Answers
SOURCE: blinking power light
To Loryd:
Please accept our apologies for an inappropriate response such as that which has been posted by adhamsaid88 here. This is not the way FixYa experts conduct business, nor is it considered acceptable or to be expected on this site.
I am not an expert on televisions, but we will attempt to resolve this situation for you. Other experts will, I am sure, weigh in on this who are much more knowledgeable on the matter than I. I am sure they will help you, and you will not see the type of behavior that unfortunately has been displayed by adhamsaid88. I have posted a notice to other experts to ask them to look at this matter, as well.
My only thought would be that you may have experienced some type of power surge or other power-related incident. This could, in theory, have affected lamps and/or circuits... If you are knowledgeable in these areas, it probably would be a good idea to check for any such obvious problems. However, make sure that it is unplugged so that you don't take an electrical risk, and another true expert should be getting back to you.
Please feel free to post back if you do not receive enough assistance to resolve your issue, and accept our apologies for the unacceptable response posted previously by this individual.
Thank you for using FixYa - we will work with you to try to help determine the cause of your problem!
Posted on Jun 29, 2008
Why is power light blinking
is it yellow as it blinks or red? if yellow check the kill switch located at the base of the lamp compartment cover ensure it presses the switch lever in order to ser the tv to standby mode the yellow blinking will stop and u will see a stable red ready for switching on
Jul 19, 2013 | Toshiba 61H71 61" Rear Projection...
To Loryd:
Jun 28, 2008 | Toshiba 61HX70 61" Rear Projection...
LCD Won't Power On
Blinking of power light is fault indication. From the number of blink that occur at one time switch ON, you can get an idea about the faulty circuit side. These are called blinking codes. To know more about these blinking coded, visit the site. It has details about blinking codes to many brand TVs. Pull up older posts. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Apr 22, 2013 | Televison & Video
2001 Dodge Ram 1500 2WD truck. From time to time the turn signals won't blink. They light up but do not flash. They will sometimes begin to blink and then stop blinking. Sometimes they blink,...
check the earths on the lights and the bulb wattage ,it should be 21watt ,but if its the weird funny system on a american car then who knows ,where the stop light is the indicator and it flashes red and cuts out ??
May 25, 2011 | 2001 Dodge Ram 1500 Truck 2WD
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
The red power on light just blinks. Tried leaving it unplugged. Still didnt work
Ours was doing the same thing, we changed 3 little black fuses in it and it works. I do believe they are 5 amp but not positive, we found them through a tester. When I have the exact answer for u I will email u again sorry u have had no response till now probably does you no good now..It's been awhile since they were changed.
Nov 01, 2008 | Toshiba 61H71 61" Rear Projection...
Toshiba 61HX70 61" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
