Navigon 2100 Max Portable GPS System Logo
Posted on Nov 14, 2008
Navigon 2100 text to speech not working
My navigon 2100 used to speak street names...this function has stopped working. The steeing are enabled and I have depressed the reset switch. Any ideas on how to get it talking again>
  • Anonymous Feb 06, 2009
    my stoped speading as well.
  • Anonymous Aug 13, 2012
    In settings/sound/ voice make sure you have NOT chosen the Default Voice. You need to select Lynn as the voice to get the text to speech street names.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
521
Points
The same happened to my 2100 3.5 inch. any remediatons?
My garmin nuvi 255w does not speak street names. How do I set it up to speak the street names?
I'm afraid the 255w does not speak street names. A satnav needs to have "Text To Speech" capability before it can speak the names and the 255 doesn't have it.
1helpful
How do i get my garmin 255W nuvi to speak street names, it speaks turn at net left or right but no names
The Nuvi 255W is capable of TTS (text-to-speech) and speaking street names. Please see this link on how to set the unit up to speak street names:
http://www.sharc.net/discus/messages/6/74.html?1260198848
- Jim
1helpful
New unit does not announce street names...nuvi 255wt unit
Please see this link on how to enable the TTS (text to speech) mode so your unit will speak street names,
- Jim
21helpful
My Garmin 255W doesn't speak the name of street, why?
You will need to do the following to get your unit to speak street names.
Tools/Settings/Language/Voice,select one that has TTS after its name.
I would suggest that you go on Google and download the 60 page complete Manual which also has Troubleshooting in it.
Will not speak street names
The One XL will not speak street names, but the One XL-S will. Text-to-Speech is the main difference between the two models.
6helpful
I have a Nuvi 255. It does not speak street names
Did you select Text To Speech (TTS) one?  If the voice doesn't have (TTS) it won't speak street names.
3helpful
2answers
Garmin Nuvi 260 - how to activate text to speech
Make sure the voice you have selected has the letters TTS next to it.
Street names no longer announced
The 200W isn't supposed to have text-to-speech (where it actually speaks the street names). If yours did initially it was probably loaded on the unit by mistake at the factory. That feature isn't part of the 200W or it's software.
2answers
Speak street name
Select a voice with TTS (Text to speech).
67helpful
10answers
Question: How do I change the Voice Language setting on my nuvi 2xx?
--> Answer: All of the Garmin® automotive GPS units that speak street names are also loaded with basic voice prompts (example: Turn Right in 500 feet) as well as Text-to-Speech (TTS) voices that speak street names. If one of the basic types of voice prompts has been selected, the voice prompts will not speak street names. In order to change this setting on the nüvi® 2xx series, follow these steps:
  1. In the Main Menu, touch Tools (Wrench icon).
  2. Touch Settings.
  3. Press the Down arrow in the bottom right corner.
  4. Select Language.
  5. The first line on this screen is the Voice language. Touch the Current Voice option for the GPS device listed to change the Voice.
  6. Select a Voice that is labeled TTS. These will speak street names. Options without the TTS label will say the distance until the next turn, but will not include the street name.
  7. Select OK. The Voice has now been changed.
The device should now speak street names. This is tghe solution that I found on the Garmin site. It worked for my device. Hope this is helpful. solution = solution1description.innerHTML; Last modified on: 04/14/2008
--> Other recommended links Next Solution >> nuvi 260 nuvi 255 nuvi 200 nuvi 270 nuvi 205W nuvi 260W nuvi 250 nuvi 250W nuvi 255W nuvi 205 nuvi 200W -->
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
