Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark 1185 I am reinstalling my printer to my pc (Windows XP) using the installation disk. I get the message the ''spooler system is off click yes to start''. I click and nothing happens. I am out of the installation process.
    Genius:
  • 1,124 Answers
  1. Go to Start, Control Panels, Administrative Tools, Services.
    Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
  2. Right click on the print spooler and select Properties.
  3. Click on Dependencies to view a list of all the system components that the print spooler depends on.
  4. Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Posted on Nov 14, 2008
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
I need instructions on how to install my lexmark office all in one with fax x4270. i used the cdrom and I have a usb port
install the cd first. and do not connect the usb wire first and follow the instructions.and connect the usb wire when it prompts u to connect the usb wire.
Oct 07, 2008 | Lexmark Office Equipment & Supplies
Software for printer dissappeared from my system when I try to reinstall driver I get message that spooler service has stopped do I want to start it I click yes then I get message that operation cannot be...
1st You download Printer Driver. Lexmark Printer Driver Free After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 18, 2010 | Lexmark X2350 All-In-One InkJet Printer
Can't reinstall printer- ''print spooler is not working''
If you have the windows disk for it , Save everything important to disks.  Put WIndows  disk into machine and tell it to install. It will find you version and ask if you wish to repair it, Say yes.   If you have Xp pro just "Restore" computer to the date before the problem started. If you have neither one. Save you work and then reinstall everything using your backup disks.
Mar 18, 2009 | HP Computers & Internet
I purchased a lexmark 1185 and do not have disk
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Feb 10, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Pentium4 computer
To start print spooler service, go to start > run > services.msc then press enter. scroll down the list to find print spooler, then right-click then click on start. You need to have it automatically start in the future, so you have to right-click > properties > startup type > change to automatic. Then try reinstalling your printer if necessary.
Sep 06, 2008 | Microsoft Windows XP Professional With...
Error 1068 on vista print spooler stopped
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Aug 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark z600 printer.
since you removed everything, take it one step farther. Try using SYSTEM RESTORE (assuming you have WIN ME or later). This will restore the register for Windows OS. Select a restore date from the list to when you thought the system worked fine-go back to the earliest date if necessary.
Sep 09, 2007 | Lexmark Z600 InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
