Question about Mitsubishi WS-55807 TV
Mitsubishi WS-55807 calibration
Hey i just bought an old Mitsubishi WS-55807and i need to know how to properly calibrate it is there anyone who can solve this?
  • Anonymous Dec 03, 2008
    i turn the power on and the green power light flashes rapidly but no picture or sound
  • 1665 Answers
SOURCE: Mitsubishi WS-55807 hour glass shaped picture
If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual and try by yourself see link
Posted on Mar 23, 2008
SOURCE: Mitsubishi model No. WS-55807 - In need of schematic please
I have a WS-55807 that will not power up. When the power button is pressed I hear a click from the back of the set, the timer light comes on and 3 seconds later I hear a click from the back of the set, and the timer light goes off. I started checking power to the unit with a voltmeter. For those intersted I have attached scematics: I verified that the PCB main fuse is good and there is 120V at point PT. 9f453c1.jpg
From what I can tell is happening, the power button is pressed and the P-ON transistor is given a signal to conduct which causes K9A50 to close. K9A50 opens after about 3 seconds.
I am looking for other troubleshootinng steps. I have checked fuses F9A01 and F9A06, both are good. What are some other things to check for? Where does the P-ON signal come from?
In the switched supplies regulator circuitry I found fuses F9A04 and F9A05 blown (denoted by red lines thru components). I jumpered around F9A04 and F9A05 with good 5A fuses and the TV powered on. However when the set was plugged into an outlet there was a huge power draw (sparks from the outlet).
After jumpering around the blown fuses, the TV stayed powered on for about 30 sec and then powered down. I pressed the power button a few more times and the same result. The TV stayed on for only 30 sec.
I pulled the middle PCB whichs holds these circuits and I found the
D9A60 diode open and IC8C02, one of the convergence IC's fried. I don't know if these were like this before or after jumpering.
I replaced all bad components and I am back to square one. The K9A50 relay stays closed for 3 sec and the set does not power on any further.
Comment by TV_ITGuy, posted on Dec 19, 2007 Thanks for the advice ctf1800. I have read several posts that speak of the DM unit. I have looked in the back of my set and the DM unit is not in the location shown in the pictures. dcb8806.jpg
As I hope you can see in this picture, there is no DM unit to the far left, just open space. Also the service manual for the V17 chasiss does not speak of a DM module.
I checked the reisitors on the output of IC8C02 which are a couple of 3.9 ohm resistors in parallel. When I test them I get approximately 1.9 ohms, which is what it should be with them being in parallel.
Please let me know if I am off base on any of this. Thanks Comment by TV_ITGuy, posted on Dec 19, 2007 Also, I have replaced both of the Convergence IC's when I replaced the fuses and diode. postsolution.gif Post Solution
addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Dec 19, 2007 2%20stars.png
Rank:wizard_s.gif Wiz
Rating: 84%, 2716 votes
first off you should replace both convergance IC and check the resisters coming off the output if any of the resisters are bad it will trash the ic on trying to power up.
i would also replace the caps in the DM section
Comment by ctf1800, posted on Dec 20, 2007 there are six fusible return resistors ranging from 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms. I would lift one side of the resister out.
check for any caps that look puffy and check the horz. out put transistor.
Rating Locked! (?) TV_ITGuy has rated this solution as Thanks for Trying
Hope this helps
Posted on May 29, 2008
SOURCE: Mitsubishi WS-55807 TV won't turn on
I have the same problam,I got this tv for free and i am trying to find out what is wrong with is so i can fix it.has any of yall got yalls fix if so what did you do to get it to work.
Posted on Jul 01, 2008
  • 927 Answers
SOURCE: Mitsubishi 55 inch Digital TV WS-55807
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Sep 25, 2008
  • 6784 Answers
SOURCE: Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Posted on Feb 19, 2009
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Jul 30, 2016 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807, screen removal / cleaning
Hi, thank you for visit fixya.
Pull out the speaker cover ( slow toward your self).
You will see screws in the middle , take it out ( maybe is 4 o 6 screws), be careful with any wires connect to panel control. Disconnect any connector to panel control. Pull toward your self , slow and slide up . Use a fine brush for best result, use glass cleaner liquid.
Any question, I will be here.
If you need additional help, please send me a picture front tv and I will show the right process.
Thank you
Dec 05, 2009 | Mitsubishi WS-55807 TV
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Tv doesn't come on
Mitsubishi WS-55807 Manual
I think that the solution that you are seeking is on page 63 of the manual.
Feb 12, 2009 | Mitsubishi WS-55807 TV
Cable box
Yes, this TV will need a converter box if you are getting off-the-air reception. It does not have a DTV tuner built in (too old) although is a high-def capable set.
Dec 06, 2008 | Mitsubishi WS-55807 TV
Ws-55807 convergence
I had the same issue for months and finally had to have a tech come by and fixed it - $400.00 later.
Aug 13, 2008 | Mitsubishi WS-55807 TV
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
