Question about Trident JT-513 Wired/Wireless Professional Microphone Microphone
Receiver does not seem to work anymore...
Hello all, I have the receiver plug in my system. It used to light up when it was plugged and the receiver and mic were put to On. Now, I can't get anything... I know the mic works cause I replaced the wireless signal sender with an xlr cable and everything is working... Any suggestions ?
  • Anonymous Mar 14, 2009
    MIC WORKS ON A CORD, BUT NOT ON WIRELESS,CHANGED BATTERIES
2 Suggested Answers
SOURCE: Set-up wireless karaoke Mic.
Thanks, so much and I already kind of tried that. What I mean is that... it does not have the standard output RCA cable, instead it only has a one prong cord (it is a larger, headphone (like) cable with one big prong on each end). I tried to plug it into the headphone (output) on the JVC which of course didn't work. This is the only place to plug directly into the stereo JVC receiver. So I went to Radio Shack (they are so not techie), they talked me into a stereo to mono converter. It converts from the one big prong to the 2 red/white RCA prongs. I plugged the one prong end to the Trident Mic receiver, then took an RCA cable and plugged that into the other end of the converter then into the DBS port on the JVC receiver, turned everything on and ta da nothing. However, I wondered about the color scheme and the Radio Shack guy said it didn't matter. I will go home and check the connection. I was pretty sure that I had to do something with the mode (your analog/digital comment). I will go home and check that, too.
Thanks for posting. It sure seems like it should work pretty easy, but so far no go.
I will post back, in the meantime, if you have anymore suggestions, please be sure to post.
Ciao and Much Appreciation,
Beth
Posted on Dec 31, 2007
Receiver USB port Reading "No Storage"
Jason
I have the same problem as you with <no storage> using the UBT-1 on an Onkyo TX-NR616. Any device can connect to the UBT but the AVR does not seem to recognize the UBT-1 device.
Very annoying for such an expensive AVR.
Dec 11, 2012 | Onkyo HT-S3500 5.1 Channel Home Theater...
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
I have a STR AV1020 receiver. If I leave the power cable plugged in, even if the system is off, there is an issue. When I power on the receiver, all lights come on and stay on. Sometimes playing with the...
Hello i have a Sony str-av 1020 reciver. But reciver is burned power supply transformer. At the transformer walks around 125 v, but i don't know how much Current transformer on the other side is, and i don't know what transformer i have to buy? Please help. I would be very grateful!
Mar 08, 2010 | Sony Audio Players & Recorders
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
Used receiver at different location for 3 months.
Had repair man come. The coax connection going to TV from receiver had went bad in the receiver. The other connectors in box worked but not the coax anymore that is why the box worked on other TV since using video and sound cables. Got new box for signing up for another 18 months with Direct TV. Didn't have to have splitter to just get Satalite so that wasn't the problem at all. Any of the splitters I had would have worked.
Apr 17, 2009 | RCA R10 DIRECTV
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
I can't seem to find any technical details on the output specifications of the karaoke mic, but IF it outputs in consumer standard RCA format (a cable with two ends, one red and one white - often seen with a third yellow cable for video), then you should be able to plug it into the back of the receiver without trouble. Simply choose one of the audio connectors in the back to function as your microphone playback system - I suggest the DBS connector, unless you have a satellite system already plugged in.
Connect the Red RCA cable to the RIGHT channel port on your receiver and the White RCA cable to the LEFT channel (Red = Right). Now, select the DBS (or whatever port you plugged it into) using your receiver remote control. Hit the "ANALOG/DIGITAL" button on the remote until "ANALOG" mode is displayed.
If you want to connect the mics to a Karaoke system using the same receiver, simply unplug the White RCA cable from the Microphones, and plug in the White RCA cable from your karaoke device. Now, you'll get music playing from one side of the speakers, and mic playback from the other side, simulating the karaoke experience.
NOTE: If the microphones do not have a RCA plug on the back, please post a picture of the reverse of the Microphone receiver, and I will see what I can do to help you further.
Dec 28, 2007 | Trident JT-306A Microphone
Top Trident Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Trident Audio Player and Recorder Expert? Answer questions, earn points and help others
