Plastic parts that hold metal bar with hooks has broken off
With super glue!!!
Posted on Nov 16, 2008
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Looking for a replacement for the folding mechanism of a p&t vibe 1
Hi
I was wondering what side clip you are missing???
It has been ages since you have posted, not sure if still searching???
Nov 30, 2012 | Regal Lager Phil & Teds Vibe Jogger
Metal bar under front tires of 2006 Kia Sedona disattached from sockets
Its probably the stabilizer bar or part of it.
You can go to the auto parts online stores and look up suspension parts for your make and model to see photos of the parts.
Aug 21, 2012 | 2006 Kia Sedona
While typing there was a metalic "clunk. The paper would no longer remain around the bar.
There is a strong spring tha holds the lower rolls on the paper it may have broken but more likely the plastic point where it hooks broke off.
DickyO
Jun 24, 2012 | Brother SX-4000 Typewriter
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Jan 14, 2009 | 1997 Toyota Camry
98 Jeep Wrangler door handle won't open door
there is a metal bar inside that clips into the handle they come off all the time there is a plastic clip that hold the 2 together it most likely has fallen off and into the bottom of the door you can put it back together easily if clip cannot be found you can buy them at local parts store for a couple bucks..hope this helps
Nov 21, 2008 | 1998 Jeep Wrangler
19 people viewed this question
jasbo
jasbo
