Panasonic PV-DM2093 Triple Play 20 in. TV/VCR/DVD Combo Logo
christopher lee tindall Posted on Apr 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What fuctions does my remote do and how.and why cant i get a dvd to play
ICANNOT PLAY A DVD OR FIGURE OUT HOW TO USE A PLAY STATION ON MY TV
Anonymous
Level 3:
Top Expert:
  • Panasonic Master 14,553 Answers
  • Posted on Apr 17, 2012
Anonymous
Panasonic Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718012
Points
48227
Consult owner manual about hook up and if no picture on DVD or does not play them at all either mechanism or optical pickup in that unit is dirty or bad.
My tv remote has sync with the dvd and I cant make it go back to the tv???
use the remote av button to scroll to an av section that reconnects the tv
probably have av 1, av 2, av 3 etc and one is for the dvd, another for the play station connection another for the cd player etc
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Have lost all my hd tv stations
Hello
Just reset the TV to factory settings and retune it using auto tuning fuction from the Menu option.
To reset it to factory settings, do the following:
Turn on the TV. While holding down "UP arrow" button on the remote control, press the POWER button on the TV. [The TV will turns itself OFF and then back ON again. Release the "Up Arrow button.
This operation will clear all your customized settings including Paremtial Lock settings.
in otherwords, this is the process to unlock the TV if it is locked.
Retune it by autotune fuction. All the lost stations will emerge again.
Ok.
I cannot get the Vcr/ Dvd to play
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
2helpful
Mikomi lcd/dvd icannot program the tv to any stations
Have the same problum they say my signal board went bad and I cant find a part to get it fix the com. went bankrupt.
3helpful
2answers
I have lost my remote
Original and replacement remotes: www.remotes.lt
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Cant find code to work our durabrand tv
if ur directtv remote works withy ur tv use it i have a tv that can not use certian remotres cause it has am/fm radio/dvd/vcr/tv so some remotes just are not in to off brand or multi use fuctions
2helpful
No remote
I found out that a company named 'Kids Station' makes the tv. Unfortunately, they are not on my universal remote list. If anybody could figure out which codes work, please post them!
Here are two links which have the compant name.
http://www.coinoptoday.com/newsflash/news/warner-bros_2006-01-18_kid-station.html
http://www.planetkrypton.net/category/Electronic_Products
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
