Question about HP Computers & Internet
New Compaq Presario SR5590AN Desktop I was persuaded to buy the Belkin Easy File Transfer Cable Now the file transfer is a disaster without the cable with the system locking up even trying to delete one file. There may be a conflict with Windows Easy Transfer? All the related files have been uninstalled or deleted. David Nuske
BFixed
  • 104 Answers
SOURCE: I have installed Belkin "Easy
There are two places you can look...
Under: Start button - Programs - StartUp, any items in the Startup list will automatically be run when you start your computer. Simply Right-Click on any suspicious entry and select 'Delete'.
Second Place: Select Start - Run, Type In: msconfig and click Ok.
In the config utility go to the StartUp tab at the top. In this window
you can uncheck items that you do not want to start when you turn on your computer. Any checked items will be automatically run when you start the computer. The availability of the config utility is dependant on what operating system you are running.
Posted on Mar 09, 2008
  • 35 Answers
SOURCE: I have purchased the Belkin
Have you set the computers up for sharing the drives?
Posted on Mar 15, 2008
  • 177 Answers
SOURCE: easy transfer cable
Too risky as the cable may or may not be configured for two of the same OS.Transference by CD would be a better option.
Posted on Sep 19, 2008
  • 162 Answers
SOURCE: deleted dll
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini
DEL C:\Boot.ini
BootCfg /Rebuild
Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console.
When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
Posted on Dec 01, 2008
  • 5 Answers
SOURCE: Janome MC 10000 with Easy Transfer using jef files
Try saving your Monogram Wizard design to your computer. Then open Easy Edit and Import the design using the drop down menu under File. Manipulate the design and then send it to the machine using Write designs. You will have to make sure the design is going to fit in the hoop correctly before you save it to .sew in the Monogram Wizard program. On the save screen... near the bottom there is a box about turning the design sideways and this is often the problem. Will be glad to talk more. tjsews@gmail.com
Posted on Mar 02, 2009
Old pc w/disk drive laptop no disk drive.
If both Pc's support the cable and software The cable which I recall was a null modem cable, then yes if your laptop has a serial interface.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Using a belkin easy transfer cable with only one monitor
Hi there. You can use the same monitor for boh the computer (just consider the annoyance of having to go to computer one, do the trick, disconnecting the monitor and connecting it to computer 2 and so on). If, what you want is to extract the files from the old pc because you are going to get rid of it and want to save them, I"d suggest you get a Hard Drive External Enclosure (between 20 and 35 dollars from most places). Connect such hard drive to it and read it via USB interface (or probably E-SATA or Firewire. Depending what do you have in your computer). Hope it helps, good luck.
Jan 05, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
File transfer with Dynex cable
USB transfer cables are quite special and not a regular USB cable.
A better (and cheaper) option is if both have network ports (Ethernet)
Then use a crossover cable. This is usually much much faster than USB and also more reliable.
Enable file and printer sharing on both computers.
Also make sure they both share the same work-group common examples are MSHOME or WORKGROUP
Once that is done you have a few options.
The better option is to use file and settings transfer wizard or similar built into windows. This will step you through the process and allow you to carry over your email and address book plus all your documents.
Another is to use copy and paste to pick the items you want and move them directly to where you want them (his does not work as well as the FST option but is quick just for documents etc.
Dont try to copy programs as they don't transfer well for the most part.
If usb is your only option then be very aware that USB 1.0 to any USBwill be extremly slow and even subject to failure. USB 2.0 to USB 2.0 is the only reccomended usb transfer method
Sep 07, 2009 | HP Compaq Presario V2000 Notebook
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Does Belkin transfer programme files?. Also I want to know if this product transfers from XP to XP, desktop to desktop. Basically, I am moving from a 20gb to 80gb hard drive and want everything to be in...
A transfer cable kit will only transfer files and settings to another computer. What you want to do is have your 20GB hard drive imaged to a clean 80GB hard drive. That would transfer everything and give you extra space.
Some people call this "Ghosting" using a product from symantec called "Ghost" and another product that can be used for free (home use) would be "Drive Image XML" .
I would suggest going to your local Computer Shop and requesting this type of service.
Mar 13, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
I've purchased a belkin usb 2.0 file transfer cable for transferring old files from a pc with windows 98 to a new laptop with vista, the transfer cable is not picking up the two computers on the old screen...
Hi
Im not sure you can transfer over a USB cable with different OS and filesystems. easiast way is to buy a usb harddrive or usbstick copy data to that. or if the old computer have a networkcard to transfer over a crossover cable or true a network Hub/switch..
Aug 13, 2008 | Belkin Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
