Question about Intel DG31PR Motherboard
No video & 3 beep sound
I just got myself the DG31PR mobo connected hdd, dvd ram, 1gb ram.
But whenever i switch on the pc the fan rotates, led turns on but there is no video displayed and getting 3 beep sound. I am using p4 2.66ghz processor.....What might be the problem?
Plzzzz help me its very urgent for me to fix this problem out....
  • lampro Nov 24, 2008
    hi
    3 beeps & nothing... changed ram, hd,power supply, ... nothing (no display & fans ok)
    i think i'll try another processor...
  • Shankar G Feb 19, 2009
    when i switch on my pc i am hearing 3 beep sound and No display in monitor, But cpu fans are rotating
  • 22 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
128
Posted on Mar 13, 2009
    Scholar:
  • 44 Answers
Hi Sharang -
Here are the steps to take for that specific motherboard according to Intel
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. Note: Some systems might need to have a memory module in Bank 0.
  • Try using RAM chips from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
  • Trying known good memory in the system.
  • Check the power supply and check for power fluctuations.
  • Swap the motherboard.
Hope that helps,
Take care,
Michael
Posted on Nov 14, 2008
When I hit the power button it wont turn on. I have replaced the RAM with a known working DDR400 1GB stick, no fix. Tried switching power supplies, no fix, tried new videocard since when it was last on (a...
When you say the CMOS is set to reset, this should not be the case for normal usage. and maybe the problem if left in the on position the system will not start (which sounds like your problem).
Mar 18, 2011 | DFI NF4X INFINITY Motherboard
I am slowly rebuilding my computer. When I nearly got it finished, and turned it on, it came up with "Windows Was Not Found". Knowing what to do, I turned everything off, unplugged it properly, and...
Check for motherboard. use only 3 parts:
motherboard
PSU
CPU + COOLER
Connect your motherboard to PSU and see, if any LED light comes from motherboard. If LED is on, then try to turn motherboard on and see if cooler works.
Are case wires (power +, power -, hdd +, hdd -, reset+, reset -, power led+, power led - and speaker wire ) connected correctly?
Those wires look like this:
front-panel-headers-nsatmeh50lx5u1woeaeqllmn-4-0.jpgThis image is just reference.
If the power wire (sometimes called POWER SW) is not connected correctly, when you press the power button of case, PC just won't turn on.
If PC turns on and CPU fan spins, then try to add RAM, Graphics card and try again.
Next step is to hear BEEP sound. One short beep sound is normal, anything else is not normal and indicates the problem of the specific hardware according to the sound code. Sound code is BIOS dependent. In case ASUS A8V-E Deluxe, it is Award BIOS. Check below for Award BIOS beep codes
1 long, 2 shortIndicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
1 long, 3 shortVideo card not detected __ (reseat video card) or bad video card
Beeps repeating endlessly __ RAM problem.
Repeated high frequency beeps while PC is running __Overheating processor (CPU)
Repeated beeps alternating high & low frequency ___Issue with the processor (CPU), possibly damaged
Mar 17, 2017 | ASUS A8V-E Deluxe Motherboard
Recently built a PC Power is On with No Display
Well depending on your bios version, it could be an array of things.
First try removing the video card and re-seating it.
Then re-seat the RAM.
If the problem persists re-seat the CPU.
Let us know the exact model of your motherboard so we can better troubleshoot your problem.
When you turn on your computer the system does a POST (Power On Self Test). If the POST sees an eror it will tell the BIOS (Basic Input Output System) and the BIOS will beep a code or display a code that indicated the problem.
Different motherboards contain different BIOS versions. BIOSes use different beep codes for problems depending on the manufacturer.
Mar 24, 2009 | Abit IN9 32X-MAX Motherboard
Win XP re-starts after Turn Off computer.
hi im josh! may i help you? i had the same problem of yours before but it was already resolved.i found out that the power led connection was mislocated. you can found this inside the pc.on the motherboard connection to power button.two small wires there try to check. hope i helped you.good luck.
Feb 19, 2009 | Computers & Internet
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
No beeps, No video but fans and lights come on...
Its the DG31PR bios!
Put a non 45nm CPU on it, update the bios to the latest one , put back your 45nm processor and all should work just fine....this board is awesome.
Cheers!
Apr 18, 2008 | Intel DG31PR Motherboard
No Video
Its easy to test your MB and CPU.
Just remove all components from *********** board, like CD-ROM, DVD disk, HDD, FDD or any PCI or USB component.
Add a speaker to *********** board.
Add CPU, and without RAM.
Now switch on, there must be along beep for RAM not found, if you don't get any beep it means your MB or CPU is faulty.
In other case if you got the long beep, then switch off and add your RAM to MB and switch on again. Now you will get an ok beep. It means every thing is ok.
Now attach your Keyboard and monitor and listen if you get the ok beep or not and also see the monitor there must be light on your screen and message to insert bootable disk.
If every thing is passed ok, then add your HDD and boot.
I think you can do the rest..
Thanks
Iqbal
Mar 10, 2008 | MSI K9VGM-V Motherboard
Won't boot or start, fans and leds work
Are you hearing any beeps when you start it up?
Dec 17, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Intel DG31PR Motherboard Logo
211 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
