HD LCD TV while viewing HD programing the screen freezes or breaks up.
    Champion:
  • 225 Answers
Sounds like a bad signal. Realign your satellite until you get a better signal.
Posted on Nov 14, 2008
Hd channels need to adjust stretch and normal view
That usually is an adjustment made on whatever source you have hooked to the tv. Some tv models will minuliplate the picture but not all.
Feb 04, 2014 | LG 47LG70 42 in. LCD TV
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Haier tv I am hooked into Bell Expressvu. HD receiver and I can't get the picture to expand to the entire tv screen. i can only find HD Normal and it stays in a small screen view.
It might be necessary to change the resolution/Aspect Ratio (Screen Size) settings on both your HD Receiver and your TV.
I don't have Bell Satellite but I do remember having the same issue setting up my friends HD TV and Bell Satellite TV Receiver.
Nov 25, 2013 | Haier HL32D2 32 in LCD TV
I have a Polaroid 42" TV and the screen does not
if its a hd tv try viewing a true hd source and the grey areas should go away. you might have and resolution button on the remote that will toggle between screen modes. look for that button and give it a whirl and also make sure yoiu view a true hd program
Dec 24, 2010 | Polaroid Televison & Video
How to program a Sansui model #HD LCD 2200 for digital tv. I no longer have cable and have misplaced the user's manual.
HI,
this is the manual and you need the cable tp program it...you can get it easily at a affordable cost
http://tv.manualsonline.com/ex/thread/view/idThread/2442932
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | Sansui HDLCD-2200 22 in. LCD TV
Sony lcd tv picture freezes
I saw the solution posted to your problem talking about the picture freeze feature on Sony TVs. I presume you're not touching a button on the remote when your picture is doing this.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. If your TV has this picture freeze feature the other guy was talking about, it's possible the feature is now malfunctioning . Whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced. Follow the link below and it will take you to Sony's esupport page. There you will find a phone number you can call, or you can chat with someone online regarding your particular issue. Good Luck!
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Aug 04, 2009 | Televison & Video
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
26" Philips HD ready tv (LCD)
Nothing much you can do. The soft plastic will get worse if you try anything.
The screen could be replaced, but would cost more than the TV.
Jan 29, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
