Question about Kenmore Elite 45986 Front Load Washer
My new washer bounces around the room like its posesd
It makes alot of noice, floods the floor, bouces around hard & very loud for my family and neighbors. Its wont even finish a load itll turn off half way drain and sit there then when i turn it on again it stars over again. please help me i dont know what needs to be done. I wonder if cause i bought it at a sears outlet store if i can get a manual or a matag guy to look at it and tell me what needs to be done to set it streight. thank u for ur time.
amy porter Blackcloud_6969@hotmail.com
    Scholar:
  • 68 Answers
How does it flood the floor from water bouncing out, or leaking and the machine bounces too?
First thing, got get a level, a bubble level from a hardware store, lay it on the lid and then on another vertical surface and see how far how of level it is, then use the adjusting knobs on the feet to get the machine with the bubble right in the middle, and then let me know how that helps or does not, sounds like you have a ton of problems, and even getting it at sears outlet it has a warranty or should, what do they say?
write me at wbwill@sbcglobal.net when you get a level and tell me how level the machine is when you first lay it on there I will try to help you
Will
Posted on Nov 14, 2008
  • 958 Answers
have you removed the shipping bolts at the back before you run the unit?
if it is brand new, it is shipped with mounting bolts at the back that holds the unit securely. look at the back and you will see notice there about shipping bolts that you need to remove.
tnx 4 using fixya,
drcool
  • markexcg Mar 23, 2011
    I have the same problem where the bolts were in it and there was no warning sign or tape on the machine to remove them. Now the machine is trashed!!! How do I get Sears to cover this?
Machine dances around room on spin. Floor is level and concrete
Is it making a loud thump? If so, it may be the basket drive. If not, the suspension to the washer may be damaged.
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My MAH9700 bounces all over the floor when spinning.
I just purchased this washer used and the family that owned it had rubber discs that the feet of the washer set into. Then one side of velcro the size of the discs was stuck to the floor and the other to the rubber disc. The rubber disc acted as a shock and the velcro keeps it from sliding around. That should do it.
D.
Dec 08, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer shakes violently when going into spin
Adjust the legs on the bottom of the washer so that all legs are touching. requires a 1/2 or 9/16 inch wrench to loosen the lock nut then adjust the leg to where they touch the floor evenly plus a 1/8 turn then try it. If it still bounces around you may have a mount that has come loose, if so post here and I will Post what to do next.
Nov 02, 2009 | Splendide 2100 Front Load Washer / Dryer
WE MOVED THE UNIT TO THE DINING ROOM TO HAVE NEW TILE INSTALLED. NOW THE ICE MAKER ISN'T WORKING AND NOT MAKING ICE. WE HEAR A LOUD SHHHHHH NOICE EVERY FEW MINUTES COMMING FROM THE BACK. WHAT CAN WE DO TO...
Is it hooked up to a water supply? If not, you are heaqring the water valve call for water and no water is available. If you are using plastic line, it could be kinked. You should change it to copper anyway as plastic very often fails and floods.
Apr 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Loud spin cycle/water leaking
If your washer is making a "freight train" like noise in the spin mode, ( loud roaring ), this is often the spin bearing built into the bottom area of the transmission that is worn out. This bearing is part of the transmission and means a new transmission is required. The noise is usually a result of water leaking from the center seal and bearing area onto the transmission. This water washes out the bearing and it gets very noisy in the spin cycle!! Do check the easy stuff before condemning, nail/pin caught in one of the inner basket holes, nothing is caught in the drain pump, the inner wash basket is not loose and wobbling around.
Jan 14, 2009 | Kenmore 44102 Front Load Washer
Vibrating machine
have you check your floor..if floor is weak the hold area around unit will vibrate,,,easy test,,,stand in front of unit and bounce your body up and down things moving,,,weak floor,,cheapest fix..get a piece of pluss carpet and make 1 piece over all for legs,,when unit settles in thick carpet that will stop bouncing and noise
Dec 09, 2008 | Maytag MAH8700A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
161 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
