Question about Video Game Consoles & Games
Aristocrat Elan We have a Aristocrat Elan 2 up 10 cent Poker Machine.A few months ago a family member got a jack-pot price , so we switched the machine off. It then asked for a Attendant ,It then started to make a tivking noise from the speaker and the light keep flashing near the reset switch .We do not have a key for the reset lock so I pulled the wires off and rejoined them back to gether again and stll the same. I then pulled it apart and cleaned up the around the gears but stll no good [Iam sure the gears are set all right].Have you got any ideas as to our problem. Is there a manual for these machines and what would it cost. Joe.
Check Ebay for the Ainsworth Poker slot machine manual. Though its for the Aristocrat-IGT import version it will help you.
Posted on Mar 26, 2010
Son bought Gold membership when a special price of $39.99 was offered thinking it was a family membership
Hi. Microsoft will give existing Xbox LIVE Gold members a prorated discount on the purchase of a Family Pack. For each month remaining on your current Xbox LIVE Gold subscription, Microsoft will reduce the purchase price of a Family Pack by $5. For example, if you have six months of your Gold subscription remaining, you qualify for a $30 discount and will only be charged $69.99 at the time of purchase. If you have 20 months or more of your current Xbox LIVE Gold subscription remaining, you can upgrade to an Xbox LIVE Gold Family Pack for free. You will not receive a refund for any remaining subscription time in excess of 20 months. I hope this helps!
Feb 27, 2011 | Microsoft Xbox Live 12 Month Gold...
We have a j1045 samsung washing machine which has been serviced 7 times in the 4 yrs we have had it. we are now having problems with it draining and spinning. this is the worst machine we have ever had. we...
these machines have a very weak impellor connected to the main shaft of the pump. usually allways break, forntunately it is the cheapest part, unscrew the filter cartridge,pull it out, get your finnger in there and check the impellor for looseness it will be flopping around if its broken, buy a new one and fit it,theres just a few screws and 2 hoses attached.
Dec 21, 2010 | Samsung Washing Machines
Xerox 5252 running
You will need the contract. All Xerox machines made within the last few years unfortunately REQUIRE a XEROX authorized laptop computer in order to make any adjustments or to even get into the service mode. You can do the normal stuff and just pay by the call down the road when you need it but Xerox will charge you an arm and a leg for parts and labor.
If the machine is new, depending on your monthly volume you should expect to pay about 1 cent per page Black and 8 cents per page full color. Again these prices can vary based on your volume. The more pages you run the cheaper the cost per page.
Good Luck
Nov 20, 2009 | Office Equipment & Supplies
Machine is only a few months old, but somehow the pot cracked. How to replace pot?
Thanks, but I ordered a new coffee pot from the manufacturer (the one I have cracked).
Oct 15, 2009 | Maximatic Elite Cuisine EHC-2055 10-Cup...
Bunn thermal coffee pots not keeping coffee hot
If might not be the thermal pot, it is possible it is the machine itself. If you have a candy or meat thermometer, place it in the pot as soon as the coffee has completed brewing. The temperature should be at 175-185 degrees. If it isn't, then the machine needs replaced. If the temperature is correct, then please call customer service with the model and date code to get the thermal carafe replaced. If the temp isn't correct, and it is 3 years old or less, the machine will be replaced for no cost. If it is over 3 years old, it can be replaced at a reduced price.
Jul 12, 2009 | Bunn Coffee Pots: Thermal Carafe
Need to clean and lubricate
Use a soft brush and maybe some air, but be very careful not to knock any springs loose. Sewing machine oil or TriFlow oil works best. Put a fews drops on your finger, and rub your finger across the type segment slots. Work the typebars a few times. If that doesn't do it, then the segment will need a thorough cleaning.
May 18, 2009 | Royal Office Equipment & Supplies
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
BUNN CWTF-15 Not brewing full pot, only 1/2 pot..?
If this problem started after moving the machine, pull the machine out a little & look behind it for a kink in the tubing coming to the brewer. These brewers time the water coming through them, so if a kink is restricting the water flow, running the same amount of time equals much less coffee in the airpot.
Oct 03, 2008 | Bunn CWTF 15-TS Coffee Maker
My tablet won't dissolve.
Sounds to me like the dishwasher isn't filling up with cold water. I had a similar problem a few months ago, caused by limescale blocking the inlet and drain valves. Might be worth trying some kettle limescale cleaner solution and putting it inside the machine - and leaving it overnight then trying the machine out with no dishes etc in it.
May 16, 2007 | Whirlpool 24 in. ADP5962 Free-standing...
Video Game Consoles & Games Logo
256 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
