Question about Kenmore 78570 / 78571 / 78572 / 78574 / 78579 Gas Kitchen Range
No ignition spark
We moved the stove to lay new floors, and when we reconnected, the gas works, the oven light goes on, but their is no ignition spark to light the burners. No clicking at all.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like you knocked a wire off something, theres1 module problably behind unit that controls all the clicking for entire stove, i would check there first
Posted on Mar 01, 2008
Random spark from igniter
it sounds like the wire that goes to the stove igniter is shorting out when you are using the oven.
Jun 09, 2014 | KitchenAid KGST307 Gas Kitchen Range
Oven will not come on
Does your clock work? This sounds like either a lack of voltage to the oven igniter, or a failed spark igniter or both. Your oven igniter is the easiest to check. With broiler door open or the plate above your oven burner removed, turn your oven on and look for a red to white glow near your ovens burner. This is a ceramic glow plug, and it will not allow gas to leave your manifold until the igniter has reached the proper temperature. If there is no glow, then your igniter has failed and needs to be replaced. The spark module that clicks as you turn your burner has obviously either died, or there isn't enough voltage being supplied to allow it to start up. Unplug your 110v wire from the stove and try a hair dryer or other 110v appliance at the wall outlet to determine if you have proper voltage there.
The worst case scenario is that both your oven igniter and spark module have died, which is rare unless you have had a power surge or lightning strike near the power transformer to your house.
The cheapest way to test this is to buy the oven igniter first, since they are far cheaper than the spark module. If the new igniter lights up, then you can be pretty sure it isn't your power outlet, and can safely move on to the spark module.
Mar 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Fridgidaire stove
You probably have a week oven igniter. Unplug unit first!!
Remove oven floor. Remove flame spreader. Igniter is attached to side od burner tube. It removes with 2 screws. Remove drawer to access connections. New igniter will come with wire nuts. Cut wires at old igniter, strip back insulation and connect to new igniter. The 2 wires can go either way. Re-assemble and test.
Nov 10, 2007 | Ovens
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Kenmore 78570 / 78571 / 78572 / 78574 / 78579 Gas Kitchen Range Logo
197 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
