Installed cd writer in dell dimension 2100 when i try to play cd it give me erro windows cannot access the specified device, path, or file. you may not have the appropriate permisson to access the file
    Scholar:
  • 58 Answers
It is most likely a bad CD. Try other CD's, and if they work fine, then you have a scratched (visible or not) CD. If very few or no other CDs work, then you have either a bad CD drive or a bad Driver.
Try going to the CD drive's website and find an updated driver. If you already have the latest driver, try re-installing it, then restart your computer. If none of that works, then you should try a different CD drive.
Also, if your not an administrator, try accessing the drive withe Admin privileges. Also, try the CD at school or work, or a different computer and see if it works.
Good luck,
-Rolltape
Posted on Nov 14, 2008
Dell Dimension E510 dvd writer does not recognize blank dvd
Try going to device manager and uninstalling the device, reboot the machine and let it reinstall the drivers. Sometimes the driver files gets corrupted and this will resolve the issue.
Feb 22, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
My computer says CD-ROM is not available Path '1' cannot be found verify you have access to this location and try again find instalationumms1 in folder and install
Type DEVICE MANAGER in your windows search area
This will show all your computer's hardware and peripherals
Is your CD drive listed?
No-power or other problem
Yes-driver issue?
right click on the cd drive and select PROPERTIES
first tab GENERAL shows if device is working properly or not
click DRIVER tab and select UPDATE DRIVER
You may have to restart.
Please reply if this does not remedy your error.
And always specify what version windows you use.
Hope this helps.
Mar 12, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Windows cannot access specified device, path, or file... app perm
sounds to be a bug in the system
ensure the program is working, goto system restore and turn it off
turn back on again, this will remove all the old ones, they could have the bug in them,
create a restore point now, then download "combofix.exe"
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
run this
it gives a report when finished, the top section shows deletions, this is the stuff it found
Nov 12, 2009 | Dell OptiPlex GX260 PC Desktop
Ethernet Controller is missing
You are unable to use the Ethernet, VGA etc. because you have not installed the drivers for the same.
You might have received a Drivers CD(it will read "Drivers and Utilities") which will be in blue color, when you got the computer from Dell.
In case if you haven't received it you can contact Dell on 1-800-624-9897 and request for a Driver CD. I guess this Dimension model is @ End of Life (I mean no more produced by dell) you might have to download the drivers from Dell's support site (www.support.dell.com) you will have to get it downloaded on a different computer and copy on a CD or a Flash drive.
Once you got all the drivers. First extract them in a separate folder
Go to Device manager
Right click on the Ethernet controller (where you see a yellow exclamation)
Click update drivers
Show the path where you have the driver files
Sep 20, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 4700 can not install Windows XP
It looks as though when deleting the OS you might have gotten jacked and the rom drivers were lost.
Jun 25, 2009 | Dell Dimension 4700 PC Desktop
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item
It is simple ...... u got to be an administrator to install any software ..or you should be given Rights to Install any thing in the machine ...
Till then u will recive this msg on the screen
Apr 23, 2009 | Computers & Internet
Windows cannot access the specified device, path or file.
Try to using Admininstrator user and passwor or the user id and password which have preveleges.
Thanks
Iqbal
Jun 16, 2008 | Acer Aspire 4315 Notebook
System Restore / User Account Issues
1. download panda antivirus www.pandasoftware.com and do a full scan
2. Download and install the Windows 2003 Server Resource Kit Tools from
<http://go.microsoft.com/fwlink/?LinkId=4544>.
3. Click Start | All Programs | Windows Resource Kit Tools | Command Shell.
4. Type these lines at the command prompt. The second and third commands are
case-sensitive, so type them exactly as shown. Note the "+r" in the second one,
and the "-r" in the third one:
net user guest /active:yes
ntrights +r SeNetworkLogonRight -u Guest
ntrights -r SeDenyNetworkLogonRight -u Guest
5.restart pc and right click my computer - manage-users-add user and give full rights
6.restart and logon with new user
Nov 24, 2007 | Dell Dimension 3000 PC Desktop
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
