Question about Video Game Consoles & Games
We have a old Aristocrat Elan 2 up 10 cent Coil Machine. It makes a ticking noise from the speaker and the light near the reset switch keep flashing.I have tryed to reset it but it will not go.
  • joeandese Nov 17, 2008
    Thank you very much
    Thank you very much
    President:
  • 1,952 Answers
Check all the electronic components whether any thik got burst ...
Posted on Nov 15, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 15, 2008
    check connection were\ interlinked with each other
    Sergeant:
  • 213 Answers
See this is pdf form
now you can
solve your problem
http://www.stealthhomeamusements.com/media/sammy-arist-rodeo-newigt.pdf
contact me if u have any doubt regarding this
    Genius:
  • 1,239 Answers
Hi there is a short circuit see the circuit
Posted on Nov 14, 2008
  • ABHISHEK.C
    ABHISHEK.C Nov 15, 2008
    there may be loose connection to speaker repair it by soldring the wire connections
    Champion:
  • 225 Answers
Replace all the large capacitors you can. Most likely it is a power supply problem. Capacitors use an electrolyte fluid and will dry out over time. If it is over 5 years old, dry out is very probable. If that does not fix the problem, you will have to be a tech to figure out the problem from there.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to check the speaker
and then the wire
its old now!! maybe there are parts
to be replaced especially the speaker
and the wire
    Sergeant:
    Champion:
  • 283 Answers
HI,
Since the machine is old need to check its wiring inside. Thier is shorted that cause the speaker noise and light the bulb near the reset. Thank you...
    Brigadier General:
  • 6,966 Answers
Being more than 20 yr old machine would make a tech suspect anything and everything electronic inside the unit. Offhand the ticking noise could very well be a relay in a cycle of energizing/de-energizing. The flashing systems reset is an indicator of a malfunction and therefore the unit will not operate.
Whatever the problem is, the unit has to be opened up. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings if ever one could be found. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional, somebody who has maintained these machines in the 80s.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Elan wall speaker mounts
Try Radio Shack, Best Buy, Sears, or eBay.
Apr 13, 2012 | Elan SEL350 Speaker
Any suggestions on why i have a ticking noise around engine and battery warning light stays on but strats perfect
Hello, Take your Explorer to an Autozone, Oreillys, or Advance autoparts store and get a free scan on the computer and the charging system. The ticking noise you hear can be the spark jumping from a bad sparkplug coil or wire.
Sometimes an arcing part will make a ticking sound and can charge the electronics with random pulses that can cause permanent damage. It is also possible your Alternator is working below capacity and will make the Battery fail when conditions are right.
This is something which should be checked before you are stranded. I hope you find my solution very helpful in keeping your Explorer operating.
Apr 01, 2011 | 2002 Ford Explorer
I was going through a drive through and my oil light came on and was beeping. My oil level is fine. What's the problem.
The oil light comes on when there is low pressure not because there is low oil. If the engine wasn't making any ticking or clunking noises when the light cam on I would bet that an oil pressure switch will take care of the problem. If the engine had make a lot of noise and/or the light never wnet ou I would then suspect that there is a problem with the lubrication system.
If you post an engine size I'll let you know where the switch is. Typically they are near the oil filter and have a green connector.
Nov 09, 2010 | 2000 Dodge Caravan
My husband's E-Machine T2882 began to make jittery noises, the light on the front flashes as does the monitor with a ticking sounds, then nothing happens. You can't get it to turn on. We've rebooted, shut...
first look for the upgrade of the hardware's inside. like memory and processor. second if that machine is 7 yrs old, please do replace it. coz i believe the hardware's for that is now expensive.
Mar 28, 2010 | E-Machines T2882 PC Desktop
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
I have an old ideal elan 2 boiler. The pilot light has gone out and wont re-ignite. I have pressed the ignition switch in but there is not even a spark. Does anybody know where the re-set button is on...
Hi, to light the pilot you must first ensure the gas valve button (Grey with 3 symbols on it) is placed in the ignition position, then, while holding the button in towards the gas valve depress the orange ignitor button several times, hold the gas valve button in for about 30 seconds once the pilot lights. If it fails to light and you cannot see a spark when you depress the ignition button the cable could be faulty, the ignitor corroded or damaged or the pilot could be blocked or the gas turned off. If it is an Elan 2 CF boiler there is no reset button.
Apr 26, 2009 | Kitchen Appliances - Others
Aristocrat Elan
Check Ebay for the Ainsworth Poker slot machine manual. Though its for the Aristocrat-IGT import version it will help you.
Nov 14, 2008 | Video Game Consoles & Games
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
HP 6110
Is the ticking sound coming from the right side near the bottom? Or the left side near the top. If it is the right bottom then you're looking at a service station. If it is the left top then a scanner unit. Scanner unit is not available from Hp. You can try dismantling and cleaning all mirrors and lenses (usually doesn't work). If it is the service station, you are probably going need parts that are not availble.
May 01, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Video Game Consoles & Games Logo
32 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
