Question about Dell Computers & Internet
Dell Dimension E510 Powers Up, Then Crashes
My Dell Dimension E510 won't power up with the on/off switch. When I unplug for 30 to 60 seconds, then plug it back up, the CPU comes on for about 2 seconds, then turns back off. The monitor only shows a rev number.
  • g_s_valentin Nov 29, 2008
    I had it checked out by a local reputable computer shop. They said it was the motherboard. Could still be the processor, but due to the cost of a motherboard and processor along with the fact that it seems the Dell E510 appears to have more than its share of problems, I've decided to replace it rather than repair it. Thanks for your help.
  • 2,427 Answers
It's the processor or power supply. I cant be sure of which without checking it.
Check the fan over the processor heat sink to make sure its working cause it could mean that the processor is overheating If the fan turns and then it cuts off this could meant that the processor is dead. or the bios is corrupted. Try flashing the bios, there is a battery on the main boad, remove it. unplug the system first... when the battery is out press and hold the power button for 10 seconds then release. put the battery back in and try to turn it on..
If that fails then try a new power supply or one from another system to to check if the power supply is fine. YOu can aslo bridge the green and any black wire from the power supply's mainboard connector to see if the power supply runs. If all this fails then you may need to replace your processor,, I';d also recommend changing the power supply as well.
Posted on Nov 14, 2008
I have a dell dimension E510 computer it turns on but it has no vedeo or power to the key board
What exactly can you see on the screen?
A blinking cursor?
Entering power saving mode?
Try to unplug the cables and plug it back in,it should work.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 08, 2011 | Dell Dimension™ E510 PC Desktop
Dell Dimension power button flashes amber and will
open up your system get a can of air and blow all dust away could be an overheating fault
May 13, 2010 | Dell Dimension™ E510 PC Desktop
The dell dimension E510 powers off and will not stay on
This info is not enough to give you a specific solution. Try this: Press and hold on/off button for 3 seconds. Turn on button, press f8 continuosly to os start menu, choose safe mode, check sleep and hibernation settings, test for malware/spyware, check startups - run msconfig, disable all startups if needed.
Dec 16, 2009 | Dell Dimension E510 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 has a solid amber light, no light codes or sound codes. Unit powers up but will not boot. I unplugged and replugged all the wires to no avail. Does anyone have a clue as to why?
Contact dell technical support for a replacement motherboard. If I remember correctly this model had a recall due to faulty capicitors and should be replaced even if you are not under the service agreement still.
Jul 14, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Want power pins on the motherboard of a dell dimension E510
Hi, i think u need to talk to dell support chat, they will give you more info, or else try them in parallel, i mean like terminate with a screw driver or u can download the service manual for this like Dimension E510.
Hope that helps
Cheers
Apr 27, 2009 | Dell Dimension E510 PC Desktop
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Dell dimension e510 won't turn on
Unplug the power cable from the power supply in your computer and reinsert it. If you still have nothing, most likely a dead power supply.
Jan 24, 2009 | Dell Dimension E510 PC Desktop
Computers & Internet Logo
165 people viewed this question
Alun Cox
