Question about Audiovox SMT5600
Audiovox SMT 5600 will not charge
Is there a way to open the phone and check the solder joints. My phone stopped charging and if I press the connected really hard and hold it, it charges. There is probably a loose solder joint? Thanks
  • JoBott May 25, 2008
    Since I came back from a long trip where my phone was packed in my carry on bag but not used duirn the trip, it has stopped charging. At first when I plugged in the mini USB charger it would recognize the connection and start the charge, but then it would mysteriously stop charging midway through. I tried my secondary reliable charging method by connecting to my laptop through the mini USB cable, and it too won't work anymore. The PC doesn't even see the phone now. If I were to hold the car charger or wall charger AC adapter into the plug I can get the phone to recognize the charger and start charging for 15 seconds. Any slight movement on my part and it will loose the connection.
    I believe that something in the wiring/soldering is to blame and I would be very interested in finding the solution.
    I love my phone and I haven't seen any new models out that I would rather have.
    Novelist:
  • 172 Answers
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Posted on Jun 08, 2008
  • Jrussell789 Jan 31, 2009
    Note also, you must have a working Active Sync for Windows XP PC, or Mobile Device Center, for Window Vista PC, installed for this phone to charge from the USB port.
    All HTC phones, which the Audiovox 5600 is(HTC Typhoon), need a working computer with Active Sync or Mobile Device Center software in order to allow charging via USB. It is both a hardware and SOFTWARE issue. Thanks alot HTC, you bums!
I have a audiovox 6700 ppc. The battery is not holding a charge very well. I have to charge it at least once a day. The longest I have been able to talk on it at one time is 45 minutes. Why is it not...
check charger , charging point of your phone and furthermore make sure phone screen save features is set to maximum
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Audiovox PPC 6700
USB connection failure to Blackberry 8800
I have the same problem.  The following solution may apply; here is how to IDENTIFY the problem: (1) Phone doesn't connect to desktop software through USB but will through BT (if setup) (2) Phone doesn't charge whether USB-computer, USB-wall, USB-carcharger or does sometimes but you are not sure why it works sometimes but not all the time (3) If you hold, lean, twist, or jiggle the plug at the phone, it may charge or the charge icon may show briefly (Also) Plug is noticeably loose or comes out Solution: if plug is torn loose, damaged, or comes all the way out, go to this site and follow along in kind http://computerguru365.blogspot.com/2006/02/diy-blackberry-usb-repair.html If plug is simply intermittant: remove all power and the battery, open your phone, and carefully redo the solder joints of the plug.  If you don't have a SMT (surface mount) rated soldering iron w/ tip, you can use the radio shack standard but be sure to only apply the hot tip in pulses (less than/up to 50% of time, less than 3sec each touch) so you don't heat damage the surrounding components. Why: Because the plug gets tugged to the sides causing the solder joints to crack (microscopically).  At first I had to lean books against the plug but then that quit working as well.
This approach also worked on my laptop which quit charging when plug torque flexed the motherboard and cracked the solder at some surface components near the plug.  I found out which components when the varying the force of my multimeter tip cause the component to show open and normal across the solder joint
Nov 20, 2008 | RIM BlackBerry 8800
Phone does not start with sim card on it
Be sure you have SIM card in right. Look at contacts on SIM then allign them with SIM Contacts on the phone.
If this doesn't work, then SIM card itself is highly suspicious. Try it in another phone.
Nov 19, 2008 | Audiovox SMT5600 Smartphone
Helppppppppppppp
well u pronobley need a new battery
Nov 05, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Unlock
check out this link
http://www.gsmliberty.net/shop/nokia_unlock.php
i dont assure you but i think it will help you.
thanks.
Oct 23, 2008 | Cell Phones
Unlocked audiovox smt5600 will work in india?
yeah go to a cellphone repair shop and ask for an open line.
Aug 12, 2008 | Audiovox SMT5600
Computer won't sync with audiovox smt 5600
You must install ActiveSync software on an Win XP OS available with disk supplied with phone or on MicroSoft support page.
If you are using Win Vista OS, then download latest Mobile Center software while you phone is plugged into USB port.
Phone must be recognized by OS for phone to charge. Nice Audiovox/Microsoft desigh heh? Some times you just want to get designs by the throat and squeeze them.
Mar 25, 2008 | Audiovox SMT5600
SMT 5600 does not load OS, screen goes white and then blank.
Screen sound bad, or intermittent connection inside. You can find disassembly instructions on the net. Search with phone model and disassemble. Remove and reattach all cables in case one is lose or contact dirty.
Dec 17, 2007 | Audiovox SMT5600 Smartphone
Auidovox smt 5600 buzzing noise.
SOUND S LIKE THE SPEACKER IS GOING TIME FOR A NEW ONE MY FRIEND
Apr 11, 2007 | Audiovox SMT5600 Smartphone
Audiovox SMT5600 Logo
550 people viewed this question
Top Audiovox Computers & Internet Experts
Rick
Level 1 Expert
Argospete
Argospete
Goldi Kunal
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
