Question about Samsung SGH-a737 Cellular Phone
Wont charge my phone wont charge. i dont know if its the phone, charger, or the battery.
Its probably your charging port i had one that went bad and wouldnt charge too.
Posted on Nov 14, 2008
If the phone does not power what may be the cause
hi, does the screen say charging when you plug the charger in if it dont then the problem could be the screen, the battery or the charger.
if the screen lights up and says charging but the phone wont switch on then this points towards the on/off button not working properly.
if you dont know the history of the phone then to me it sounds like it could be liquid damage which means its probably not worth getting fixed.
let me know what happens when charger is plugged in ok then i can assist you further
Aug 14, 2010 | Nokia E71 Smartphone
My samsung d900 wont work/turn on
put your battery on charge on universal charger or change your bettery you will get on your mobile
Thanks
www.stylosoft.com
Jan 09, 2010 | Samsung SGH-D900 Cellular Phone
My phone will not charge
keep it on and charge it if that doesnt work then buy a new charger
Jul 25, 2009 | Motorola Mobility MOTOZINE ZN5 Cell Phone
I9 3G won't charge
I have the same Problem me and my sister both bought one about 2 months ago and now they wont charge :( such a waste of money and both batteries wont charge. Because they are from hong kong i dont know what to do ??
Jun 04, 2009 | Dual Electronics CECT P168 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Battery wont charge in phone or charger that came with it? how can I charge it?
battery may be bad and need replaceing, or the charger has a short in it or is not functioning properly. if you plug the charger into the phone its self the phone should come on with or without the batery in it. if it dont then i'd try a different charger or get a new one.
May 10, 2009 | Cell Phones
Samsung sj 600 just wont charge,
first thing to do my dear is try another charger if it wont charge it means the cellfon itself, if the celphone have the problem, change the BATTERY TERMINAL
Apr 03, 2009 | Samsung Cell Phones
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Samsung SGH-a737 Cellular Phone Logo
133 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
