Question about Microsoft Windows Vista Ultimate Edition
Auto CAD 2000 3D modelling
I need to make a 3D model (Building Interior) that gives a light effect in rendered view. The light need to be glowing in a line ..I mean to say llike a glowing rod / neon light/ tube light like this . I can only find spot light,distant light,and point light in autocad. I am using AutoCAD 2000 for interior designing. Can any one help ?
I want to download vista xp theme on my comp. so what shall i do?
Posted on Nov 18, 2008
Why won't oven light?
Hello. No make/model number was given so my help will be limited. Assuming this is a gas oven, from the symptom you described, the problem might very well be a worn out ignitor. If your oven uses the type that glows for about half a minute before ignition, it probably has come to the end of its useful life...normally, they draw about 4 amps of current and are almost too bright to look at when operating correctly. One classic symptom is the center of the ignitor element glowing brightly but not the rest. Also, if your oven has been having the "whoosh" sound when it ignites(caused by too much gas building up before ignition), that is another classic symptom of a worn-out ignitor. If you provide the make/model number, I can most likely give you the part number for the ignitor if you want to try to fix it yourself. I hope I helped you!
Sep 26, 2015 | Kitchen Ranges
How can I repair the vanity and rear view mirrors?
On most models the vanity and mirror lights are on a different circuit from the interior lights.
A mechanic would check for power at the lights then at the fuse.
Jul 15, 2012 | GMC Cars & Trucks
Does anyone here know company which could deliver 3d floor rendering services at reasonable price? Thanks in advance.
Recently, I hired 3dnanimation .com for designing my interior. They got my building interior designed with high quality interactive photorealistic 3D model architecture. The presentation was realistic and rational. Hence, I suggest you to purchase 3D floor rendering services at 3dnanimation.com.
Mar 16, 2012 | Computers & Internet
WD73732 TV-picture seems to have a "glow" or light shine especially when viewed at night. For example, faces show a glow on forehead, cheeks, nose. It is getting progressively worse. TheTV is...
You need to clean the mirror inside the television and maybe even the optics of the light engine. The dust is building up and the light cannot reflect cleanly off of the mirror.
Mar 15, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I Want activation code of auto cad 2006.plz help me. Thanks
Although it is illegal to give you the activation code for auto cad 2006, I would like to mention that there are a lot of free cad programs available out there that can do pretty much everything auto cad can do.
Here's a small list:
http://students.autodesk.com/
http://www.freecad.com/
There are a lot more, just go to google and type cad freeware, and that will get you going as well.
Oct 27, 2010 | Computers & Internet
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
Glow plug glows flame lights up after 30 sec flame goes out
If the burner assembly lights, then the problem is usually not with the igniter or regulator. More than likely the gas valve safety coils need to be replaced. There are two of them on the burner assembly. You need to replace BOTH of them at the same time.
If the model number is correct, you can view and illustration of your burner assembly here:
http://pcappliancerepair.com/model-display.php
The coils are listed as items 729 and 731. Part numbers WE4X692 and WE4X693, respectively.
If you have any questions, or if your model number differs from the one you listed this question under, please post back and let me know. I hope you find this information helpful.
May 26, 2010 | GE DBXR463GB Gas Dryer
DJ LIGHTS
MOST DJ lights are not protected to be used outside in weather.
Other considerations are visibility from highways and also aircraft. Certain lights could cause a problem for these two scenarios.
When outside, often the distances are longer and the light drops off as the square of the distance.
Laser types require fog to get the effect and there really isn't a way short of getting the weather to cooperate and give you fog to get those effects.
Between the laws of physics and the construction of lighting intended for interior use, what you are asking for is just not easily obtained.
The inability to control ambient lighting outside is a real problem. Many of the DJ things require a fairly darkened room. The sky glow from a city is enough to kill off the effects.
May 19, 2010 | American DJ Flash Beam Lighting Effect
Need to replace light inside kenmore microwave
Unplug the unit first.
To install the halogen lamp WB08X10050 you will need to take the cover off. You can see a diagram at;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=36363693302&productCategoryId=0123370&brandId=0583&modelName=MICROWAVE&diagramPageId=00006&componentDescription=INTERIOR%20PARTS%20(2)&documentId=S9060341&backToLink=Return%20to%20Sub%20Components%20list
then click on "view full size"
This will give a view of the parts. Only remove the parts needed to get to the bulb.
Mar 26, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Blurry pics indoors
1. you could try it with flash, but the lighting in the picture would look artificial, won?t reflect the interior of the building as it really is, and the flash will cover only near objects leaving the rest dark, and we?ll be missing the point. 2. recommended ? place the camera on a stable platform(table, chair, shelf etc in lack of a tripod), adjust its vertical angle by placing some flat object under the front side of the camera, set it to auto or a preference to slow shutter speed(usually 1/60 to 0.5 of a sec according to the lighting), set timer(most cameras only give you about 2 seconds) in order to avoid vibrations during the picture taking. 3. you should avoid using more then 50 to 100 ISO, more will give you a grainy effect. You are promised a sharp picture with life like colors that looks real.
Feb 21, 2006 | MitekMedia CD30P3 Digital Camera
Microsoft Windows Vista Ultimate Edition Logo
152 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
