Question about Dryers
Dryer sat outside for 5 months
Anything to check, cause my electric dryer sat outside and got rained on? I've already changed the cord and plug, it was 3 prong now its a 4prong
  • 68 Answers
You need a test instrument called a megger to tell the value of the insulation of the machine, one thing you can do is use an ohm meter between the power leads and frame, if you have a lot of resistance it is likely you can use it.
Is it inside now in a temp controlled area?
Can you get the back off with taking out probably several screws to expose the insides?
If so you can set a heater with a blower by it and blow warm air inside to dry out any wet insulation, the goal is to make sure no insulation anywhere, controls, wiring, motor is still wet and will conduct when you first plug it in.
Posted on Nov 14, 2008
Why isnt my electric dryer getting hot? too much or too little power?
if not properly wired you might not get any power
Mar 13, 2015 | Dryers
Changing from 3 to 4 prong. there is already a ground wire, not a bonding strap. what do i do with the ground on the new 4 prong cord?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Apr 02, 2011 | Whirlpool LER5636P Electric Dryer
Probably the plug end. Take it and see if you can wiggle any of the prongs. Even a little bit. If so it is probably black there already. if so replace it or the cord. If not start checking the cord where it connects to the dryer and follow the wires from there
Dec 17, 2010 | Miele Novotronic T1515A Electric Dryer
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Nov 15, 2010 | LG DLE2516 Electric Dryer
Intermittently Drying Problems, Electrical?
It could possibly be electrical, check for 240V at the supply side. The only other possibility could be plugged dryer venting, although it would be unusual for it to cause only intermittent problems. The reason the timer would stop turning (mechanical timer) or counting down (digital display), is because on any Auto-dry, (ones that use the moisture sensor) the dryness of the clothing dictates when the timer should count down or advance. Check for good airflow from the outside exhaust point, if that's ok, I would be possibly looking at the outlet for possible loose contact, look at the dryer cord prongs and see if there are dark marks on them, as this may point to a sloppy outlet causing arcing.
Nov 28, 2009 | Frigidaire Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Kenmore series 80 power cord melted
This is extremely distressing to me. If someone advised you to jump acoss (bypass) the thermal fuse on the dryer then I am in disagreement. My advise is to trip the breaker at the house power center, remove and replace the dryer main power cord, and replace the thermal fuse. Something is causing the dryer to pull more amperage than it should be, which is what resulted in the melted cord to begin with. You may want to contact a qualified appliance technician to assist in throughly checking the electrical system on the dryer. Until this condition is properly addressed there is a very real safety issue. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 27, 2009 | Kenmore 63942 Dryer
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Dryers Logo
43 people viewed this question
Top Dryers Experts
