Question about Sony Cyber-Shot DSC-S500 Digital Camera
Format error my cybershot was working fine until i went to buy a new memory stick. i tried inserting it and then the screen said format error. i even tried formatting it again, even if it said everything will be erased.... but still it did not solve the problem. format error with disk. It worked fine for awhile. when disk is out it is saying that internal memory is full, but I can only view one picture.
  • 2,427 Answers
Hmm sounds like you may have gotten corrupted..
ok here is what you do..
1.) connect the camera to the computer via the usb cable
2.) go to My computer and you should see your camera show up as an external drive.
3.) right click on it and select format. this will erase every thing and free up your memory once more.
4.) chack your manual to see what size memory card your camera support most are usually limited to 1 or 2 GB, if your card dont meet the requirments it may need to be changed.
If after your format using the above method you staill cant take shots without the memory card please insure in your camera settings that its set to save to internal memory.
Ok if all the above fails,,
1.) log on to your manufactures home page then search and download the firmware upgrade for your model camera.
2.) Upgrade the firmware using the directions provided by your manufacturer( this is usually on the page or comes with the download)
PS.. Some camera's have a flash utility that will reset it to factory condition this can also be download from the manufactures home page..
If you need more help please let me know..
Posted on Nov 14, 2008
  • 790 Answers
Hello!!
Format the memory card using a card reader thro a computer ...
  • Kanth raj
    Kanth raj Nov 14, 2008
    And also try hard resetting once!!! Switch off ur camera ,
    remove the batteries and press the power button for few seconds. then
    put the batteries back and try powering on!!
    Master:
  • 505 Answers
The problem is with the new memory stick. Have you tried replacing it?
Thanks
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Apr 04, 2011 | Sony Cybershot DSCW310 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Camera says "reinsert memory stick".
use sony memstick. try formating the stick. you will lose any picts when formating. try inserting in cpu that has memstick slot.
Jun 03, 2009 | Sony Cybershot DSC-S950 Digital Camera
Sony cybershot 3.2 mega pixels
try to putin under memory card, even in a store without buying- just to check if the problem is the card or the camera
is it a SD card?
Jul 02, 2008 | Cameras
Sony
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony Cyber-Shot DSC-S500 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
