Question about Jenn-Air JJW8130D Electric Single Oven
I am unable to have the door close fully
After replacing the springs on the door I found out that there is not enough tension to fully close and seat the door. I can not find a way to increase the tension
    Novelist:
  • 108 Answers
Sometimes those springs hang on a hook with "notches" so that you can increase the tension by moving to a higher notch. If they don't have any adjustment on them, and you just put a replacement spring on I'd start looking other places for the problem first. If you got the closest springs they had at the hardware store, then you can increase the tension by curling down (thus shortening) the hook ends of the spring with long nose pliers. On a strong spring like an oven spring this will be kind of difficult.
Make sure there isn't any rubbing or other problem going on with the hinges... sometimes just a couple drops of 3 in 1 oil will do the trick.
Posted on Mar 10, 2009
I replaced my door springs but it seams the hinges pop out of the track when opening the door and it causes the door to drop down to far
Tom, I am pretty sure you have not reinstalled door quite right, try again till you get it seated into proper position.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 03, 2016 | Ovens
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
The door hangs loose. so much so that it feels as though the heat is escaping
You need new door closing hardware. The springs that hold tension
against the door to keep it closed are worn and need to be replaced.
Feb 10, 2010 | Ovens
The lower door does not close firmly. It seems like the spring load is weak. Is there a way to improve the spring tension? I have model CM302ZS (Microwave/convection oven on top and convection oven on...
There is no provision made for adjustment of springs,
I'm afraid the only solution is to replace both door springs.
Trust this helps solve your priblem.
Dec 21, 2009 | Thermador SC302T Electric Double Oven
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Oct 20, 2008 | Neff U1661 Double circotherm super...
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Jenn-Air JJW8130D Electric Single Oven Logo
221 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
