Question about HP DeskJet 6122 InkJet Printer
Printer is printing really small
When I print the printer is printing relly tiny pring. How can I change this to print regular print. I don't know why it is doing this. Maybe you can help me. Thanks
  • 1 more comment
  • Anonymous Jan 28, 2009
    mine too especially when i am printing from word.
  • tannshep Feb 24, 2009
    Wow, me too.
    Wow, me too.
You need to delete the printer and reinstall using the disk that came with the printer. I had this problem and was just trying to reinstall with what Window XP had and it still printed tiny print. Using the disk to install solved the problem. I think this issue started when there was a windows update.
Posted on Apr 30, 2009
Unable print 5a printer message unable print
how to solution 5a print unable pring Dcp 125 prin
Aug 18, 2013 | Brother MFC 6490CW InkJet Printer
Print head is stuck to the far right of the printer I have had problems in the past with the head cleaner popping up and stopping the print head from going home but now it has I think come loose and...
Hello and Welcome to FixYa!
Sir, In Epson Printers if print head is struck and it don't move then it may be because of several reasons.Mostly problem of print head struck is because of Paper Jam, actually their may be small bit paper jam in side the printer head,There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and it struck the Print Head.Open printer cover and check to make sure no paper or foreign objects obstructing the printer feederIf you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.It will clear the printer jam and it may allow you to move print head.
If problem still exist then it may be due to dirty or clogged print head which hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head and print head struck because of it. This problem can be solved if you clean the print head with software, There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printers software that will actually clean your printer for you. You can use them to clean it, After cleaning it may allow you to move the print head.If the built-in cleaning functions don't seem to do the job then There are a few ways to clean your print head manually. Its technical because you need to open the Printer, First remove the ink cartridge from the print head and take the print head out of your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it's really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle,This should get rid of any dried ink that was loosened during the soaking. Be careful, especially if you use isopropyl alcohol to clean your print heads, Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out.This process surely helps you but its highly technical so i recommend if your product is in warranty or out of warranty.If your product is in warranty, Simply contact to Epson Service Center or from where you purchased it and claim the warranty. Your problem will be solvedI hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 30, 2011 | Epson Stylus C88 InkJet Photo Printer
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
Hi, I have a epson R340, I need to set my computer to print white and black. how do I do it?
Connect printer to PC.Power on. Go to controle pannel.select your default printer..Go to printer properties.go to printing preferences.selct grapics.Set black&white.Apply and OK.Then your priter will print in black&white until U change settings.contact further details
mohanraojagan@yahoo.com
Nov 07, 2010 | Epson Stylus Photo R340 InkJet Printer
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
At first would pring in oolor only with faded
Do several printhead cleaning via the printer menu and make a test print. Mostly printhead cleanings solve the issue.
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Sep 11, 2008 | HP Photosmart 3210 Printer
Error in opening port. M1583
PLs Install Network Magic software and install and findout your ip address
May 05, 2008 | Computers & Internet
Minolta Dialta d152
It has to be one of two things.  1) The wrong printer driver for the print controller on this model. 2) Possilby, but rarely seen, a bad print controller.
Personnally I would download a new version of the driver off the konica minolta website and then go from there.
Sep 27, 2007 | Minolta Di152 Laser Printer
HP DeskJet 6122 InkJet Printer Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
