I dont have vchip code fof my used tv
I was given a Sharp model 27N-S100 tv. It has the vchip turned on and I dont have the code to turn it off. I am unable to use the tv and dont know what to do to solve this problem.I am 52 years old and dont want the vchip option.
    Problem Solver:
  • 15 Answers
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Posted on Nov 14, 2008
Goldstar pn 243813h
0387,0389,0328,0399 are the codes to check with Goldstar. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | Televison & Video
I have an old Sharp Model # 27A-S100 I have a Black Line running across the bottom of my screen from left to right 22 1/2" length and 3 1/4" in height
If this line does not go all the way across the screen then I will bet you this is an easy fix. Press the menu button on the remote control. The menu will hopefully show up over-top the black. Search your menu for the closed caption setting (usually under audio settings menu) and turn closed caption OFF. Hopefully this fixes your issue. Cheers.
Apr 24, 2011 | Sharp 27N-S100 27" TV
Is this tv digital?
No it does not have the digital tuner. You can you it if you have a cable or Sat reciever. If you wish to use an antenna then you will need a digital converter box
Dec 14, 2010 | Sharp 27N-S100 27" TV
How can I go to the main menu without use the remote control to this tv?
Hello. The only way is with the remote. If yours is lost, go to any Walmart and get a universal remote. They work great.
Regards, Joe
Jan 15, 2010 | Sharp 27N-S100 27" TV
I was given a Sharp 27N-S100 27" TV. Everything's fine but I don't have the remote control or user manual. I would like to get to the menu screen for the tv. How can I do this. Its hooked up to a cable box...
On the front of the TV you should be able to press both channel up and down at the same time and it will give you access to the TV menu. Once in the menu use the channel and volume up and down buttons to navigate.
Good luck....
Jan 13, 2010 | Sharp 27N-S100 27" TV
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
The power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Mar 27, 2009 | Sharp 27N-S100 27" TV
SHARP REPAIR HELP
changing the eeprom ic should solve your problem.
Apr 11, 2008 | Sharp 27N-S100 27" TV
SHARP MODEL 27N-S100
Flyback part number RTRNF0033MEZZ
Nov 10, 2007 | Sharp 27N-S100 27" TV
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
Electro Med Services...
