Question about Technics RS-TR373 Single Cassette Deck
No sound on cassette deck
I went to turn on the tape deck and it shows the tape is playing, but there is no sound out of either deck. All the connections are good and I have cleaned the heads. I lost the manual and cannot find a place to download one for free. Any suggestions. I don't use it that often, but the last time I used it, everything was fine.l
  • haywardtec May 13, 2008
    first,actually my deck is rs-tr313.
    secondly,it was playing and then just suddendly the sound stopped,
    thirdly, no meter to show whether thr signal is coming through from the tape.
    Thanks for any suggestion which I can get to..
  • 50 Answers
Hi Does the deck have VU meters?...or a graphic display of some kind to indicate there is sound being picked up from the heads? If there are, and they are not moving or flashing, as the case may be, then you could have a wire off the head, or a problem in the preamp circuit, or if the deck is older, it could be as simple as a dirty play/record switch. I would need more info to help further. Good Luck!
Posted on May 02, 2007
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Cassette deck won't open or play tapes
Take it to a Panasonic authorized service center. They'll fix it.
Apr 01, 2009 | Technics RS-TR575 Single Dual Cassette...
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR373 Single Cassette Deck Logo
2,128 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
