Question about HP LaserJet 3030 All-In-One Printer
Printer jam upon exit
Hp3030. just as the printed page is about to fully exit, there is a paper jam warning sound and lighs and the very last centimetre of paper is stuck within.
there appears to be a drum/toner scrap across two lines nearing the bottom of the page, sometimes it will fold/crinkle too
  • jlfordpty May 14, 2009
    I have a similar problem. The paper feeds through but comes out wrinkled and with a sticky roller line running the full length of the right side of the paper. How do you "disassemble the output paper assembly" to clean the rollers?? I have removed ink cartridge and been able to clean only the limited areas I can reach. How do I get inside????
    Scholar:
  • 78 Answers
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Posted on Nov 19, 2008
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
Prints one page and jams, displays paper jam
so it does print and exit one page before it jams? if so you have something wrong with the exit sensor. if it does not feed it all the way thru it might not be feeding paper in to the machine fast enough. the feed tires might be dirty.
Sep 23, 2014 | Samsung Ml3312nd Black White Laser Printer
Why does the printer keeps having a paper jam fault on final exit slot?
It sounds like the exit sensor is sticking, so the printer doesn't know the paper has exited & throws a jam.
Aug 24, 2014 | Cannon Office Equipment & Supplies
Paper jams just before it comes out. Complete image has printed but the page doesn't "come out", gets jammed. If doing 2 page print usually only half of the second page will print as it backs up behind 1st...
This sounds like a classic fuser failure. Take the printer to a qualified repair facility and they can replace the fuser and check all of the fuser and exit drives for proper operation.
Jun 16, 2010 | Brother HL-5240 Laser Printer
Paper Jam
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | HP LaserJet 4mv Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
Lock down
Is sounds like your exit sensor actuator has been knocked off. It's not seeing the paper hitting the exit sensor and shutting down.
May 08, 2008 | Xerox Phaser 8200 Laser Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
HP LaserJet 3030 All-In-One Printer Logo
259 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
