Question about Mitsubishi WS-55513 55" Rear Projection HDTV
My Mitsubishi VS-4542 is not receiving any signal. Please help.
The only thing I noticed is the (Set A/V Network) menu option is set to off and is stuck. It won't let us select any of the other options. Could this be the problem? What can we do?
Annabel
    Genius:
  • 2,920 Answers
You might have the tuner checked out to see if its bad or not.usually when theres no signal it means the tuner has gone out
Posted on Nov 24, 2008
Hdmi inop all 3 inputs
First thing to check is that you actually have a source signal FROM the HDMI output. Second thing to check is the cable. The audio is embedded into the signal path, so if you don't receive picture, then you shouldn't receive audio.
Check the above on a neighbours set etc, before then having to check TV settings. Finally, do a factory restore on the TV set, via the menu driven software.
Nov 20, 2013 | Mitsubishi WD65737 65" DLP TV
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS-50803 Big Screen TV - Trying to hook up an HDTV cable box, I was told to hit: menu, 1, 3, 7, 0 - to get to the service menu and switch DTV over to HD and that would solve my no signal...
First please confirm actual model number on rear of set.
Something is not right here, I am looking at Mitsubishi material downloaded in my computer; shows all codes for sets up to 2004. VS-50803 is a VZ6 Chassis made in 1998 and I doubt it is HD set, if it is one of the early ones it will have beneath the HD input vert sync and Horz sync---those required a special box from Mitsubishi etc.
Set has 3 hidden menus:
1. Option menu (for hard reset)= Menu 1,3,7,0 enter
2. Circuit adjust menu= Menu 2,3,5,7 enter
3. Convergence adjust menu= Menu, 2,3,5,9,enter (#4,5,6 on remote then change modes)
Does the DTV input have the two vert, horz jacks as well?
First is the Option menu is really only for a hard reset of the entire set, if you engaged it you may have de-converged the set.
The adjust menu is for height, width etc
The convergence menu is for convergence.
If you did something and did not save it, unplugging set should put it back to before what you did.
In the OPTION MENU WHAT DID YOU SELECT AND DID YOU HIT ENTER WHEN YOU FINISHED?
STEVE
Oct 08, 2011 | Televison & Video
I have a mitsubishi vs-4541/4542 tv with sound and no picture. What are my options?
I have not repaired this particular model. If this TV is a projection set,you have one of two possible problems. First....You may have convergence IC that has lost a ground contact to the signal board. We are discussing the board that has all your RCA connections and RF connectors. You may have to replace, possibly a STK-XXX series convergence IC. One or two capacitors near this IC, usually a bad cap will end the life of an IC and resistors. And replace a couple of resistors, these are standing tall next to the convergence IC. The next problem could be on the power supply. The power supply will almost always have the flyback transformer on it. If you can locate the vertical IC..This IC may need resoldering. You will see rings around the pins of the vertical IC. Replace the three or four capacitors next to the IC. A bad capacitor will overheat an IC and cause solder grounds to separate. Thanks for asking and show a few hands of support!
Dec 09, 2010 | Mitsubishi Televison & Video
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Channel volume
Make sure that the sound setting in the menu are NOT set on SAP. The sound should be set on stereo. Use the mitsubishi remote to pull up the menu then go to the audio portion and look for that setting. If you need more help or it is set on stereo let me know and we can go further.
Tim
Sep 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-55705
Well the "B" is the B tuner make sure you have the cable on the "B" input on the back of the set. If so, does the "A" work? If the A works then you can just use it and you probably have a bad tuner in the TV but you have 2 in this set. If niether work you've got problems. You might check the Home theater settings in the menu under A/V reciever. Mitsubishi used to lock the inputs to a certain input or channel for use with a monitor out on a reciever. If none of this helps better get a pro to look. Good Luck
Apr 04, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi 5051
I can help you here follw my pictures and be sure you have a reciever hooked up so the TV can identify it.In some cases like in picture #2 you have to tell the TV that its on by entering it in your self ,(notice the pic.2 Ive selected NO on right side ) you have to use the Volume /Enter keys to make the change,and you probably already learned that you have to highlite each move your at that your changing.d116022.jpg9f9fa1f.jpg
Mar 17, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Nothing happings
jen, Please verify Model # and mo / yr off the label on the back of your new set.................................T.
Nov 23, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
