Question about Minolta EP4000/5000 CS/PRO Copier
Error code C004A M5 fan does not turn
Removed M5 fan and had it tested on a bench. Worked great with 24volts applied to red and black wires. Pages T-63 and T-64 from repair and troubleshooting manual seem to say to reset some dip swithes on PWB A. Not sure if I understand that properly.
If needed where might I obtain a repacement PWB-A? Is there a wrecking yard for old copiers? I worked for Xerox 22 years ago so I'm not completely in the dark of the magic in the box. This machine is used and needed badly by a non-profit organization that helps a lot of very sick people of which I am one of the healthyier. Any help most appreciated. Thanx, Jim
    Problem Solver:
  • 17 Answers
This motor runs at a reduced speed for part of the copy cycle - just because it bench tests okay does not mean that it is good. The bushings sometimes get clogged with dust, etc. A drop of light lubricating oil on the shafts may do the trick. The fan should spin freely.
The troubleshooting manual is simply telling you how to use the I/O Check feature of the copier to live-test the motor and determine if the problem is with the motor or PWB-A. This is done from the control panel in the service mode. See the "Switches on PWB's" section of the manual.
The problem is likely with the fan rather than PWB-A.
Posted on Nov 14, 2008
Best way to test exhaust fan in tv
The set may have more than one fan but---look on the fan as usually the voltage it uses is indicated--if so and removed apply the same voltage to it with it removed--either it runs or not.
There should be a service manual available online free for this set--the schematic will show what voltage is used....
that error code is just a general indication of what is wrong--if fan not getting voltage, not getting turned on, or bad.
Jun 01, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
Error code C-004A
C004A Exposure fan problem
You will have to take this printer in for repair. Unless you can remedy yourself?
Aug 03, 2010 | Minolta DiALTA Di620 All-In-One Laser...
Giving code of "C004A". What does that mean?
A C004a code is a error code with a fan in the copier. It is either not working or is making a noise. You may be able to hear the affected fan and try to lubracate it. There is a Trouble reset botton behind the cover of the display contrast knob. Its on the inside front cover above the fixing unit. Try to rest the code there first. Good Luck
May 04, 2009 | Minolta EP4000/5000 CS/PRO Copier
Fan motor does not turn
FIRSTLY HOW MANY WIRES ARE COMING OUT THE FAN MOTOR AND WHAT COLOUR DO YOU GUYS USE AS LIVE AND NETURAL IN YOUR COUNTRY.
MOHAMED
Sep 19, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
EP4000 C004A error
Open the back and check the fan that is probably suppose to **** air out of the optics area.
where the light comes on and scans across the glass
Sep 09, 2008 | Minolta EP4000/5000 CS/PRO Copier
EP3050 error code C004A
May 27, 2008 | Office Equipment & Supplies
Bhupathi
the compositive power supply is the problem
Dec 23, 2007 | Canon imageRUNNER 400S Copier
204 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
