Question about Panasonic SDR-H40 HDD Camcorder
The LCD only works in a certain position
The LCD of the camera only works when I have it turned opened LCD out flush to the camera body, The opposite to when it is closed. Any suggestions? Thanks!
  • miltw3 Nov 14, 2008
    See pic below
    Sorry sent a linked photo. Here's a better one.
    Problem Solver:
  • 10 Answers
Flat cable connecting LCD unit to main board broken. Whole "shaft unit" have to be replaced ( LCD hinge with flex cable). Panasonic part #
LSEP8449A1
Posted on Nov 14, 2008
Can we repair/replace the lcd of old film cameras? I have an old pentax sfx camera and its lcd does not work.
I just checked my SF-1, and the mirror will go through four cycles while trying to load the film. You should be able to hear the mirror go up and down when you open the back and close it, then turn the camera on. I cannot get my SF-1 to keep the mirror up. Check to see if you have the mode set to bulb, and that the shutter release isn't stuck down - that will keep the mirror up until you release the shutter button or turn the camera off.
Also look carefully inside the lens mount on the side nearest the red dot. at the horizontal spot there is an internal button. It should be at the bottom of the track it runs in, about 1/3 of the way from the screw below the red dot to the lens release button. That moves up when the mirror goes up, and down when it comes down. If it is in the up position, you could perhaps try to gently move it downwards. It definitely moves up and down with the mirror on my SF-1.
Jul 22, 2012 | Pentax Sfx Auto Focus Slr 35mm Film Camera...
How to turn of my camcorder jvc hm30
Assuming you mean "turn off", fold the LCD monitor flush against the body to turn off the camcorder.
Apr 05, 2012 | JVC Everio GZ-HM30 Camcorder
Hello, I opened the LCD monitor to right angles
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 01, 2011 | JVC GR-D870 Mini DV Camcorder
The LCD screen of my Sony HDR HC9 keeps scrolling vertically. The LCD behaves normally when turned flush against the body. Viewfinder is fine as well.
Jul 17, 2011 | Sony Video Cameras
I do not see any image thru the viewfinder of the PV-GS250 Camcorder. I tried to move the viewfinder tube at different inclination and extended lengths, but no light or image appeared most of the time. ...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the vewfinder LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Apr 28, 2011 | Panasonic PV-GS250 Mini DV Digital...
2001 Cavalier throttle position sensor
Look where your throttle cables etc are attached at throttle body, it should be at opposite end of the shaft that operates throttle plate in front of throttle body opening. Usually held on with Torx screws
Jul 01, 2009 | Chevrolet Cavalier Cars & Trucks
Viewer turns off (black) when folded back against the camera.
When the big LCD is black the view finder will turn on, right?
You need to replace a new hinge unit. Here is similar solution
How to fix an intermittent display LCD on Canon PowerShot S5IS
Jun 26, 2009 | Canon PowerShot S2 IS Digital Camera
Nikon D80 display window on upper right shows flashing F-- and will not take pictures What s wrong? Jeff
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
NOTE: Please rate our help to keep this free service online
Jun 10, 2009 | Nikon D80 D-SLR Body Digital Camera with...
Canon digital G5 LCD monitor problem
Very simple fix. Open the covering on the lcd screen and also remove covering that is between the camera and screen. There is a wire that goes from the lcd screen to the camera. It came out from all the twisting of screen when opening and closing. Carefully put that back in. Google keywords like "lcd g5 fix" etc. for more detailed description.
Jul 20, 2008 | Canon PowerShot G5 Digital Camera
Fuji S3100 Broken Battery Latch
There are two potential solutions that I know of, but only if the broken tabs are on the door and not the camera body. Double check which tabs are damaged.
The first involves getting a new door somewhere (good luck with that... Fuji doesn't seem to sell the parts to civilian consumers... you might try getting the part from an old non-functional one on ebay or something). The trick to removing the battery door is to push the door's hinge pin (with the door open) towards the back (LCD side) of the camera from the opposite (front) side. There is very little clearance. I have successfully used a paint can opener to do this on a S3100. You can brace the back side of the opener against the lip of the camera body and push the pin out. Once it is as far out as possible, use needle nose plier or tweezers to grip the now exposed end of the pin and pull it all the way out. Then put the new door in place and re-insert the pin... there may be a little resistance.
The other was recommended to me by a camera repair man, but I have not tried. I would probably have let him do the work, as it seems a little risky, but possible. It basically involves getting a small washer that will fit under the two latching tabs near one another on the body. After figuring out the correct position for the washer to be attached to the door that it will just slide under the tabs and secure the door, you must use a small countersunk screw through the central hole in the washer to attach it to the door. You might have to remove the rim of the door in that area with an exacto knife or something similar so the washer will fit well. Like I said, I would have probably let him do the work, but it sounds like it would work.
Another idea that just occurred to me is a little more work intensive but would probably work would be to sink a (coarse thread) screw through the door all the way into the plastic of the body (maybe 2 or 3 in different places), which could simply be unscrewed any time you wanted to change the batteries with relatively little trouble.
Good luck! =)
Feb 08, 2008 | Fuji FinePix S3100 Digital Camera
Panasonic SDR-H40  HDD Camcorder Logo
174 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
