Question about Compaq Armada M700 Notebook
Stop code 0x000000ed going into power saving mode and shutting of
Computer shutting down in power saving mode
  • rjsingh2005 Jan 10, 2009
    automatic shut down giving error code 0x000000ed , even not starting in safe mode
  • 837 Answers
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Hi, Everytime I turn on my DELL Dimension 5150 I am faced with the following message: A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE...
This sounds like it can not mount your boot file from hard drive which needs to load windows. Sometimes this will happen if you leave a floppy, cd or some kinda usb flash drive in computer when rebooting and it does not happen always. I would try to boot in to safe mode as message is saying. To boot in to safe mode modet computers use F8 key. Turn off your pc and then as soon as you push power button start tapping key F8 located on top of keyboard. You can stop once you get screen that says Advanced startup menu. Choose option Safe mode and press enter. You will need to use arrows to make selection. Once you choose safe mode wait for the loading to be done and then choose ether your windows name or Administrator. Once in safe mode you will get error message just ignore it and press yes. When windwos comes up try to do a restore to previous date. Go to start-programs-accessories-system tools-system restore.in system restore choose restore to earlier time and on the calendar choose date that your computer was working fine. I usually go even week prior to when computer stopped working. Your data will be saved but if you have installed some programs you might have to reinstall them. Hope this helps.
Nov 06, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Stop 0x000000ED (UNMOUNTABLE_BOOT_VOLUME)
Hmm seen this a few times. This is most commonly caused by your NTFS format layering being corrupted. Meaning that the partition was either not completed when u loaded the operating system or the format has been corrupted from "hard shut downs" This is turning the pc off with the power button instead of going to "start" button and doing a soft shut down. U can try retrieving the format back but u will have programs that no longer responde. Easiest way to solve the issue is reloading your operating system.
Jun 24, 2010 | Dell Inspiron Mini 10 Notebook
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Optiplex gx280
if you just reinstall instead of new install it should save all the files you already have just reinstall in the same partition
Dec 26, 2008 | Dell OptiPlex GX280 PC Desktop
Since yesterday, cannot boot up my PB IMEDIA 1529 in XP. I get a screen message to say that Windows has been shut down to prevent damage to my computer. Trying to boot up using Safe Mode ends up with the...
Boot your system in safe mode then check, its booting or not, if boots restore it to some previous date, or change the RAM then check
please rate this solution i appreciate it
Nov 01, 2008 | Packard Bell Computers & Internet
When i put my headset to charge it stops charging after 5 seconds
if you are using the USB port on the computer to charge it, it may be an issue of your computer going into "Power Save" mode and shutting down the USB power. I found this by google searching "usb power save mode"... Possible Fix: 1. Click on "Start" and then right-click on "My Computer." 2. Click on "Properties" and then on the "Hardware" tab. 3. Half-way down on the right, click on "Device Manager." 4. Click the "plus" sign in front of "Universal Serial Bus Controllers." 5. Double-Click on the first "USB Root Hub" (not USB 2.0 Root Hub). 6. Click on the "Power Management" tab. 7. Uncheck the box that says "Allow the computer to turn off this device to save power." 8. Click "OK" and repeat for all other "USB Root Hubs." 9. Finally, close all and go back to the desktop.
Jun 07, 2007 | Motorola Mobility H700 Wireless Headset
Compaq Armada M700 Notebook Logo
193 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
