Question about MSI Computers & Internet
New notebook will not find wireless network even when right beside the router which other devices have connected to
  • bassaras Nov 17, 2008
    No, this laptop does not have a wireless switch. The driver was installed on the PC.
    I figured out that FN + F11 enabled wireless.
Have you check if you enable the wireless switch on your computer?
make sure you install the wlan card driver for it.
Posted on Nov 15, 2008
Where is the wifi
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. Most new HP (Hewlett-Packard) Pavilion notebook computers as of August 2010 include an internal wireless networking adapter, used to connect to a wireless network or router. Once connected to a router, the computer can connect to the Internet or other computers on the same network. If the wireless networking adapter is not allowing the computer to connect to a router, there are several steps that can be used to remedy the problem. Ensure that the wireless network adapter is turned on. Most HP Pavilion notebook computers have a switch that allows you to turn off the wireless adapter. The switch typically is located on the side of the computer or on the front. Ensure that the router and modem are plugged in and functioning. Ensure that the lights are illuminated on each device. Attempt to connect wirelessly using another computer, if possible, to test whether the connection problem is with the router or modem. Unplug the router and modem. Leave the power off for approximately 30 to 60 seconds, then turn them on again. Update the wireless network adapter driver using the computer's "Device Manager." To access the Device Manager, right-click on "Computer" or "My Computer," depending on the version of Windows, and click "Device Manager" from the left-side bar, or from the tab labeled "Hardware." Once in the Device Manager, expand the section labeled "Networking Devices" and right-click on the wireless network adapter. Click "Update driver software" to begin searching for an update. If an update is found, follow the onscreen instructions to install the update. Reinstall the wireless networking adapter if updating the driver does not remedy the problem. To reinstall the wireless adapter driver, right-click on it from the Device Manager and select "Uninstall." Once the device is removed from the computer, restart the computer. Once Windows loads, it will automatically detect and reinstall the driver. Run the Windows 7 Diagnostic Tool (if the computer uses the Windows 7 operating system) to diagnose any networking issues the operating system may be able to correct. To access the Windows 7 Diagnostic Tool, open the "Start" menu and type "Network" into the search field. Click "Network and Sharing Center" and then select "Diagnose and repair" from the left-side bar. The Windows 7 Diagnostic Tool will automatically run and will attempt to repair and establish the wireless connection. Attempt to manually connect to the wireless network. Open the "Network and Sharing Center" and click "Setup a new connection or network." Enter the network name, security type and network key into the text boxes and click "Next." If successful, click "Use the existing network" and then click "Connect." The network name, security type and network key can be obtained from the network administrator or by logging into the router. For help logging into the router, consult the instructions included with the router. You only need to do the following if the driver cant be installed. Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure key scroll http://support.microsoft.com/
Feb 14, 2013 | HP Pavilion N5495 Notebook
Why i cannot install a wi fi driver for my hp g7-2118nr with a windows 7 ultimate operating system
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. Most new HP (Hewlett-Packard) Pavilion notebook computers as of August 2010 include an internal wireless networking adapter, used to connect to a wireless network or router. Once connected to a router, the computer can connect to the Internet or other computers on the same network. If the wireless networking adapter is not allowing the computer to connect to a router, there are several steps that can be used to remedy the problem. Ensure that the wireless network adapter is turned on. Most HP Pavilion notebook computers have a switch that allows you to turn off the wireless adapter. The switch typically is located on the side of the computer or on the front. Ensure that the router and modem are plugged in and functioning. Ensure that the lights are illuminated on each device. Attempt to connect wirelessly using another computer, if possible, to test whether the connection problem is with the router or modem. Unplug the router and modem. Leave the power off for approximately 30 to 60 seconds, then turn them on again. Update the wireless network adapter driver using the computer's "Device Manager." To access the Device Manager, right-click on "Computer" or "My Computer," depending on the version of Windows, and click "Device Manager" from the left-side bar, or from the tab labeled "Hardware." Once in the Device Manager, expand the section labeled "Networking Devices" and right-click on the wireless network adapter. Click "Update driver software" to begin searching for an update. If an update is found, follow the onscreen instructions to install the update. Reinstall the wireless networking adapter if updating the driver does not remedy the problem. To reinstall the wireless adapter driver, right-click on it from the Device Manager and select "Uninstall." Once the device is removed from the computer, restart the computer. Once Windows loads, it will automatically detect and reinstall the driver. Run the Windows 7 Diagnostic Tool (if the computer uses the Windows 7 operating system) to diagnose any networking issues the operating system may be able to correct. To access the Windows 7 Diagnostic Tool, open the "Start" menu and type "Network" into the search field. Click "Network and Sharing Center" and then select "Diagnose and repair" from the left-side bar. The Windows 7 Diagnostic Tool will automatically run and will attempt to repair and establish the wireless connection. Attempt to manually connect to the wireless network. Open the "Network and Sharing Center" and click "Setup a new connection or network." Enter the network name, security type and network key into the text boxes and click "Next." If successful, click "Use the existing network" and then click "Connect." The network name, security type and network key can be obtained from the network administrator or by logging into the router. For help logging into the router, consult the instructions included with the router. Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure key scroll Hope this helps.
Jan 03, 2013 | HP Pavilion G7-2118NR Notebook
I have my ECS elite group W330, I bought it year 2006. My problem is, its wireless network connection cannot detect a signal even if i am already beside our router... does the age of my laptop matters to...
first click start in the computer then click run then type CMD then the dos modebox will be seen then type ipconfig then you will see ip adress of the network to which you are connected then type ping the ip address if the pinging is ok then your laptop is comunication with the router if no pininging or ip adress right click my computer then click properties then hardware then device manager and check wether the network adaptor is marked if marked reinstall the driver and restart the computer
Jun 02, 2011 | EliteGroup ECS G900 Notebook
Hi can anyone help please, my acer 5050 wireless is not working, just installed windows
1. locate the Wireless communication switch/indicator at the front of 5050 just left of headphone jack.
2. slide switch momentarily to the right.
3. you should see "Wireless LAN Enabled" in green letters at the bottom of the screen
4. a little screen icon should appear in the Taskbar at the bottom right of the screen
5. if it has a little red x beside it, right click on it for more options.
6. if it has no red x, you were automatically connected to a wireless that is open (no security enabled)
7. with the red x and after the right click, in the pop-up, click on View Available Wireless Networks
8. in the Wireless Network Connections window, if no list then click on Refresh network list
9. click on the SSID name for your wireless router to Chose a wireless network
10. click the Connect button to connect to the high-lighted network
11. if your wireless router has security (WEP or WPA) enabled, a pop-up will ask for the network key
12. enter Network key and repeat entry in next line to Confirm network key and click Connect button
13. the little screen icon should no longer have a red x beside it
14. hovering the mouse cursor over the icon will get a pop-up with wireless connection status
Feb 20, 2011 | Acer Aspire 5050-3242 Notebook
I don't know how to make a wireless connection with this device. 2 notebooks, 1 desktop, 2 Ipads, 1 PS3 and the Wii wireless connected and working the Printer and Iomega 1 TB Media Network Hard Drive are...
Make sure you are at least using a CAT 5 cable with your device. You will want to do a couple things as well. Give your device a static IP address (manually configure the IP) from withing the devices interface (login to your device, System tab on the left and Network tab on the right). Next go to your folders you are wanting to share and click the DLNA button that corresponds with the folder you are wanting your media server to share out. You should be good to go.
Dec 10, 2010 | Iomega 1TB Home Media Network Hard Drive...
How to change channels.
As long as the router isn't faulty? You may find that something is interfering with the signal, other radio units, Phones, other WiFi devices can "Swamp" the receiver, The fact that even right beside it still isn't any good, & unless you can "up" the power level, (sometimes you can, check your manual) Then I am of the opinion that it is faulty. Ensure you have the latest driver for your PC's WiFi. too.
Mar 01, 2010 | D-Link DIR-615 Wireless Router
My girlfriends computer want connect to wifi im right beside her and my does it says she connected but when try to surf it says internet disconnected
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 07, 2009 | HP Compaq Presario CQ60Z Notebook
HP built-in wireless internet light cannot be
try this...
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Oct 03, 2009 | HP Pavilion dv9000z Notebook
Emachine notebook doesn't recognize my wireless network.
Try running the Microsoft updates or getting updated drivers for your wireless NIC. It's even possible that the wireless card in the laptop doesn't support WPA security. Unlikely seeing as how the board is fairly new, but possible. You might also want to try getting a PCMCIA wireless card and popping that in.
Jun 19, 2009 | Computers & Internet
Cannot access http://192.168.0.1
Check to see if the wireless device in the laptop is functional and not disabled by double clicking My Network Places and clicking Local Networks. Make sure that the wireless device you are trying to connect to has solid leds and not blinking, it would not hurt to restart the device. When it has solid leds click the wireless icon on the lower right side of the task bar, search for available networks, choose the one to connect to, and click connect. If everything is functioning correctly it will connect. BPCS
Dec 31, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Computers & Internet Logo
32 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
