Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint Gas oven doesn't light
The controls all seem to work, but the oven doesn't ignite.  Range works fine, broiler works fine, only the oven refuses to light.  The Pre heat light comes on, but that's all.  I've tried to see if the oven would work on a preset cooking timer, but that also doesn't get a flame in the oven, even thought it runs through the cycle and turns itself "off".  This happened once before, about 3 months ago, but after 2 days, it started working fine. The controls all seem to work, but the oven doesn't ignite. Range works fine, broiler works fine, only the oven refuses to light. The Pre heat light comes on, but that's all. We have replaced the bake ignitor switch and the oven still doesn't ignite. What do we do now?
  • tji1 Dec 04, 2008
    OVEN DOES NOT LIGHT, EVERYTHING ELSE WORKS FINE
Is the gas valve easy to replace on a gas oven?
Posted on Nov 19, 2008
  • 370 Answers
If its not the oven ignitor itself then its usually the gas valve in the range.
Posted on Nov 18, 2008
2 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Posted on Oct 13, 2007
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a problem with my Hotpoint Range; the range top works, the broiler works, but the oven does not! The oven igniter seems to take a couple of minutes to ignite the gas. It comes out quickly but then...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Replacing Igniter on Hotpoint RGB528PEAWW Gas Kitchen Range
you should have a broil glow coil at tol and one on bottom. to access the bottom, open the door and look to the back on the oven floor. ther should be a srew one on each side remove and lift bottom up. you should be looking at the glow coil. i would also remove the pan drawer for access.it would be abnormal for bth the broil and bake to fail at the same time. if this is the case i would confirm power is leaving control to the selected glow bar. they shoul pull about 3.2 amps. then i would focus on the valve. which is opened by the amp draw of the bar. one wire on the valve is common and the other feeds from the control through the valve to the glow bar
May 18, 2009 | Hotpoint RGB528PEAWW Gas Kitchen Range
Broiler won't light
gas=replace igniter(top)
electric=replace top black heating element!
Oct 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Oct 12, 2007 | Hotpoint RGB790SEHSA Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
1,507 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
