Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
When I set the timer on the * (Dry Miser, Auto setting), the dryer runs forever because the timer doesnt move. The flame appears to come on and there is heat. When I put the timer on High Heat, Timed setting, the timer moves to the off position. I have changed both Thermostats, one with two wires, and one with 4 wires and this didnt fix it. As I said, there is plenty of fire and heat.....
  • 4 more comments
  • bc_gw Nov 15, 2008
    dryer will not turn off. timer runs continous. you have to open the door to stop it. Whirlpool electric
  • danpatron Dec 19, 2008
    I spent 65$, bought a new timer, and the thing still doesnt advance in Automatic mode. This is driving me nuts. I already replaced both thermostats and the coils. There is nothing else to replace!!! Why isnt the thing moving? Note: This model, which is natural gas, does Not have a moisture sensor.
    Still need help..Comments?
  • danpatron Dec 20, 2008
    The timer moves on the timed setting though, just like the previous timer. It just doesnt move on the * setting. I think something else is preventing power to the timer on the * setting.
    Ok, I will try that. I'll unplug the orange wire and secure it so it wont ground. But what am I looking for? Purpose of this? Am I looking for a flame? Will the timer move w/the orange wire disconnected?
  • danpatron Dec 23, 2008
    Read my original posting again. The heat does come on in Auto mode. The problem is the timer never moves. No problem with the heat.
  • Anonymous Mar 23, 2009
    I have the same problem with our Whirpool Dryer Ultimate Series II. When the knob is set to Energy Preferred Setting even though the heat is on and everything looks good, the knob doesn't move as the clothes dry. When we used the timed dry setting the knob moved. How did you solve your problem.
  • Whirlpool Master
  • 8,220 Answers
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Posted on Dec 16, 2008
  • 2 more comments
  • Dan Webster
    Dan Webster Dec 19, 2008
    Send that timer back and get another one.
  • Dan Webster
    Dan Webster Dec 20, 2008
    Just for fun take the orange wire loose from the timer, put it somewhere it won't ground to anything and try the cycle in question just long enough to see if the heat will work. My theory is the timer contacts in that cycle are telling the gas valve it is in the cool down cycle and thus no heat.
  • Dan Webster
    You said the heat won't come on in dry miser and the timer won't move. Remove the wire and see if the heat will come on. regardless if the timer motor moves the timer needs replacement, my opinion.
    My reasoning is this. In cooldown the dryer is supposed to apply no heat to cool the clothes down. But instead it is in the cool down at the very start of that cycle. Just guessing.
  • Dan Webster
    Dan Webster Dec 23, 2008
    I came across this same problem 3 or 4 years ago. I ordered a timer from Midwest. So I knew that wasn't it. I kept working at it for months and finally after studying the timer pattern I discovered the timer was indeed bad. I sent it back and got a new one and the new one worked like a charm.
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
The timer does not work correctly. The timer does not move and the dryer runs forever.
If the timer doesnt even advance in the time dry cycle then you have a bad timer. However you will need to make sure that your getting heat throughout the auto dry cycle because no heat will cause the dryer to run forever. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Dryers
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Whirlpool GGQ8831L Gas Dryer Logo
931 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
