Question about Mag Innovision LT776s 17" LCD Monitor
Only 3/4 of the screen is being shown...
The display has a black bar on the bottom fourth of the entire monitor. Then the screen begins (with the start menu, etc. for windows) and I can't see to the top of the screen. I have to guess to move down the windows to see content in web pages. We turn the monitor off at night and yesterday morning I turned the monitor on & it was like this... I tried using the menu button on the monitor to adjust the width & height & also used the "auto" button but the black bar remains while the picture being shown is adjusted. I also tried completely shutting down the computer and leaving it for a day but no use...the husband says he has no idea what happened to it...
  • Anonymous Nov 04, 2007
    The bottom fourth of my screen is black every time I start up my computer.
Ok so I have actually had this happen to me before. My best guess would be that it is a problem with the video card. There may be some video drivers that you need to download. The other explenation might be that the video card over heated.
When it happened to me the whole screen went blank all together after the login screen so at that point it wouldn't load Windows. If you're still covered under the warranty then you're good and set and you could get it within a couple of weeks if you send it to a tech service (preferably the company that built it)
Hope this helped
Posted on Nov 05, 2007
White 1 in. Bar running from top to bottom of screen
Plug in external monitor to see how that works. If it does same the issue is with your laptop. If it works fine the issue is with your laptop display that needs replacement.
Aug 31, 2017 | Toshiba Satellite M65-S909 (PSM60U02W021)...
Tip
How to resize your desktop background.
If your desktop is smaller than the dimensions of your monitor then follow the following steps to get a full screen:
Setting the resolution:
1) Right click on an open spot on your desktop and select Properties at the bottom of the popup menu.
2) This will then open up the Display Properties window as shown below.
3) Click on the Settings tab (it's to the top right of the Display Properties window as shown in the image below.
4) At the bottom left of the settings tab there is a Screen resolution heading with a slider bar beneath it.
5) Slide this bar to the left or right until you find the resolution you like.
6) The click Apply when you have found the right resolution.
Sliding the bar to the left = lower resolution, larger desktop icons and less quality.
Sliding the bar to the right = higher resolution, smaller desktop icons and better quality.
NB: If you are using a CRT (older screen) the max resolution will be around 1280x1024. Newer LCD screen (flat and thin monitors) can go way up to 1920x1080 and beyond if HD is supported.
NOTE: If when doing the screen resolution changes your screen goes blank after you click Apply then immediately hold down the Enter key to restore it back to your previous settings
If this doesn't work then it just maybe the case that you need to set the auto screen fit function on the monitor itself using the buttons provided on the monitor.
This tip is useful when you plug in a monitor and the screen displays the No Signal or Signal out of Range massages. Simply change the resolution to something the monitor can handle and there you go.
You can also check out my video tutorial if you want to:
on Nov 10, 2010 | Computers & Internet
Vertical black bars screen
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Feb 16, 2013 | Dell Inspiron 9100 Notebook
Black horizontal lines across entire screen.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Dec 08, 2012 | LG FLATRON W2252TQ-PF 22" LCD Monitor
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
White horizontal bar at the bottom of the screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty usually its for 3 years
Apr 10, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
Black strip left hand side of moniter screen not being filled
The monitor should have some kind of menu, accessible through the buttons on the side or bottom. In there you can move te display area to the left. If you then get a bar to the right, you should change the monitor resolution to the highest it can display.
If the bar on the left persists, you should check wether the PC-monitor cable is properly insterted. If so, try another cable. If that doesn't help either, try another monitor.
I hope this helps,
Yannick.
Oct 05, 2009 | LG L192WS LCD Monitor
I have a u220w monitor which has a rectangular screen but the picture is square leaving both sides black for about 3 inches on each side. I want to fill the entire screen. I just had the windows vista...
Dear You need to adjust the computer resoultion to one of the following..
1088 x 612
1280 x 720
1360 x 768
you can increase it more; depends on your graphic card installed in system..
HOw to change the resoultion??
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor.
Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Let me know if it helps...
rate me..
regards,
Dec 04, 2008 | Computers & Internet
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Nov 30, 2008 | Televison & Video
1440 x 900 setting for monitor means I can't see my whole desktop on my toshiba laptop...
Not all laptops display adapters will allow the individual settings for a screen and a monitor to take effect correctly.
This happens especially when one is a widescreen and the other is a standard screen.
It seems your settings are taking effect on both screens at once instead of on each screen individually.
I assume you have adjusted te display sizes in your display settings ?
If so, did you adjust each display separately ?
You may also have to see if your display adapter has the most correct drivers. That may help.
Fran
Sep 15, 2008 | Acer AL1916W 19" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
