Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
How do I charge my sansa?
My Sansa is out of charge and I don't remember how to charge it I only have the USB cord.
  • Anonymous Nov 15, 2008
    im having REAL problems charging my SANSA SANDISK and i need REAL
    Problem Solver:
  • 3 Answers
All you do is put the usb in the mp3 and the computer and then the battery will just start to charge it takes about one or two hours
Posted on Nov 18, 2008
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    Can I recharge the battery of my Sandisk Sansa Clip MP3 player without using my computer?
    Yes. AC to USB adapters are available anywhere cell phone chargers are sold. One end plugs into a wall outlet and you can plug the USB cord from your Sansa into the other end. I use such a device every night to charge my Sansa.
    Aug 25, 2011 | SanDisk Sansa Clip MP3 Player
    This isn't a problem (I hope) but my Sansa clip didn't hold a charge for very long. Can I use my cell phone charger to charge it? It fits the connection fine.
    Yes, assuming you're referring to the connection at the end of the Sansa cord and not on the Sansa itself. The Sansa can be charged by any USB device or port that puts out sufficient current.
    Dec 06, 2010 | SanDisk Sansa Clip MP3 Player
    How to charge the Sandisk 4.0 GB sansa Rhapsody e260R .. I do not know anything about it..
    There should have been a cord included with the Sansa. It has a standard USB connector on one end and a rather flat connector marked "Sansa" on the other other end. This end goes into the slot at the bottom of the Sansa, with the "Sansa" label up (on the same side as the screen on the Sansa). The other end goes into a USB connector on a computer. Leave the computer powered on to deliver power to the Sansa.
    You can download a copy of the manual from the manufacturer's web site at http://www.sansa.com
    Apr 28, 2010 | SanDisk Sansa e260 MP3 Player
    I tried to charge my sansa clip with an ipod mains charger and now it is dead!
    You can try and reset your sansa and see if this fixes the issue.
    Connect the proper USB cable to yoru Sansa the Press and hold the Power On button and the Play button (>||) for 20 seconds
    Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
    Sansa Fuze won't charge from laptop.
    Have you downloaded the latest drivers? Have you gone into control panel and device manager, and make sure the device is enabled and allowed through your firewall? Do you have the software downloaded for it?
    You can also go to my computer, and find sansa drive folder which you can go to and check the properties to make sure device is NOT set to read or write only.
    Aug 25, 2009 | SanDisk Sansa Fuze MP3 Player
    Sansa clip wont power up unless hooked up to usb
    http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
    Windows XP SP2
    • Windows Media Player v10
    • Intel Pentium class PC or higher
    • CD-ROM drive
    • USB 2.0 port for hi-speed transfers and charging
    Make sure HOLD button is not on.
    Battery
    The Sansa
    Clip player comes with an internal rechargeable battery. To use the player for
    the very first time, remember to fully charge the battery. You can charge your Sansa
    player through the USB port of your computer, a car adapter (not included) USB port, or AC
    adapter (not included) USB port.
    Charging
    To charge the battery, please follow these steps:
    1. Connect the larger end of the USB cable into an available USB port on the
    computer.
    2. Connect the smaller end of the USB cable into the Sansa
    Clip player.
    3. The computer must be on for most USB ports to charge your battery. Your
    Sansa
    will show connected and the yellow charging indicator will appear.
    The battery level indicator will blink while charging. You will not be able to
    play while connected to the computer USB.
    4. To stop recharging, simply disconnect the cable.
    The battery can also be charged using an AC adapter (not included) or a car adapter
    (not included) and you will be able to play your device while charging with one of the
    adapters.
    NOTE: Some low-power USB ports may not be able to provide enough charge
    power. Also note that the rechargeable batteries are not replaceable.
    Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
    Sansa c250
    Get a USB cord and connect it to the computer. It will automatically charge with no software installed on your computer.
    Mar 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
    61 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
